Question about Lasko 5132 Ceramic Compact Heater
Lasko 755320 heater quit working after 1 day
Heater will not turn on, acts as if it isn't getting any power. Have unplugged, let it sit and plugged back in. Just will not work at all.
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Lasko Model 5154 ceramic heater
try your local radio shack dealer.
Posted on Dec 07, 2007
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
brainyass
  • 242 Answers
SOURCE: Poping, smoking electric Lasko 5540 heater
It depends on where the smoke is coming from. If it's from the heating elements, it's normal as dust and residue burn off. If it is coming from the control section, it's bad and the heater should not be used.
Posted on Nov 21, 2008
  • 10 Answers
SOURCE: lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Posted on Oct 16, 2009
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Posted on Nov 18, 2009
Heater works fine but cold air
thermal fuse is usually the first to go check it for continuety
Nov 16, 2013 | Lasko 755320 Ceramic Electric Utility...
Fan will not start its not frozen it turns free?
Check and see if you have power at the fan wires, if you do replace fan motor.
Feb 22, 2010 | Lasko 755320 Ceramic Electric Utility...
Whenn I turn my Lasko htr model # 5132 on it beeps twice n acts like there is no power. what can I do?
unplug the heater. clean the vents in the back using a vacuum cleaner hose attachment. wait 15 minute and plug the heater back in. This has worked for me.
Feb 14, 2010 | Lasko 5132 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
Lasko 5132
There was a recall on this model and it was deemed a fire hazard as the plug can overheat at the base.
Apr 08, 2008 | Lasko 5132 Ceramic Compact Heater
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
No power
Go to the Lasko Website and get a new one for free. They were recalled
Jan 17, 2008 | Lasko 5540 Ceramic Compact Heater
Lasko 5132 Ceramic Compact Heater Logo
408 people viewed this question
Top Lasko Heating & Cooling Experts
Dave
Level 1 Expert
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
