Question about Brother IntelliFAX 4100 Laser Fax
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
  • 23 Answers
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Posted on Jan 12, 2009
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
Apr 09, 2010 | Brother IntelliFAX 4100 Laser Fax
Have a brothers intellifax copier - fax about 5
clean laser... if still there change drum.. if still there clean ccd... if still there... contact brothers support and they will walk you through it or send you to a service center for it to be repaired
Oct 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 fax m\c
http://www.brothersupport.com/Facsimile/User/um_zlefax.pdf
Setting Station ID
You should store your name or (company name) and fax number to be printed
on all fax pages you send. The telephone number you enter will be printed only
on your cover pages and call back messages. (See Composing Electronic Cover
Page
, Page 6-6.)
1 Press Menu, 1, 3.
2 Enter your fax number (up to 20
digits), and then press Set. You must
enter a fax number to proceed.
3 Enter your telephone number (up) to
20 digits), and then press Set.
If your telephone number and fax
number are the same, enter the same
number again. The number appears
on Cover pages.
4 Use the dial pad to enter your name
(up to 20 characters), and then press
Set.
(See Entering Text.)
5 Press Stop/Exit.
The LCD returns to the date and time.
If your Station ID has already been programmed, the LCD prompts “1” to make
a change, or “2” to exit without changing.
Aug 25, 2009 | Brother IntelliFax-2820 Laser Fax
When receiving a fax I get either big black plotches all over the page or thick black vertical lines running the whole length of the page to a point where I can no longer make out any of the information...
Try making a copy of something or printing a transmission report or journal from the "reports" menu. If the same problem is apparent on these printouts, then your drum unit or toner cartridge need to be replaced
May 06, 2009 | Brother IntelliFAX 4100 Laser Fax
Output coming out the back
Hi Christi_Matt !!
the brother 4100 does not have any settings for that, all you have to do is to close the rear cover just move the machine arrown and you will notice that the cover is in the up position, make sure you move it down (lock it down) and as simple as that all your faxes should go to the front.
any other questions let me know.
just use my fixya ID at yahoo.... you know the rest
thank you.
Mar 24, 2009 | Brother IntelliFAX 4100 Laser Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Does not scan pages until it makes connection
yes, the solution is that you are direct sending the faxes instead of scanning into memory which will start and complete the scan of all the pages as it begins dialing and transmitting. there should be a key on the control panel for memory or memory transmission, select it and your done.
mikey
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxes received are so light, the page looks blank
don't forget to try other fax-paper... your's might have already expired.... if this doesn't work... the printer's heater might need changing.
goodluck... hope this helps.
Feb 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 multifunction LASER
There is a door open in the back. Close it.
Sep 07, 2006 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
