Question about Nikon Coolpix L120 Digital Camera 14.1mp 21x black 26253
Nikon L120 shutter release button has to be depressed very hard to work
Very difficult to take a picture
  • 3 Answers
There is a known design issue with the shutter release switch on the L120. They start to fail after about 1500 shots have been taken. The cause apparently is oxide build-up between the contacts, even though the switch is a sealed unit.
The \'half cock\' works fine, but the shutter release requires considerable pressure to take the shot. It gradually gets worse until it eventually stops working altogether.
There is presently no known solution since the switch is a sealed unit, and is soldered to the internal circuits of the camera. A spare switch is not available on its own- so the entire internal electronics need to be changed.
The replacement part will also fail after the same number of shots have been taken (if you are unlucky), since the same component is still in use.
Solution is to get a new camera. Sad, but true since it is not cost effective to repair.
Posted on Feb 22, 2013
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Posted on Jun 01, 2008
Shibbymusic
  • 12 Answers
SOURCE: NIKON D300
This should make no difference the way the camera performs. I believe that it is the buffer for shooting in burst mode. Is it on all the time?
It should just flash every time when you half depress the shutter.
Hope this helps.
Drew
Posted on Nov 17, 2008
dbarchitect
  • 150 Answers
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Posted on Jan 21, 2009
  • 14 Answers
SOURCE: nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
Posted on Apr 11, 2009
SOURCE: faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Posted on Sep 27, 2009
My Kodak EasyShare Z612 camera has horizontal or vertical lines thru a picture that can be seen in picture review.
The screen needs replaced.You can them Ebay, and they
are not that difficult to do yourself. Good Luck
Apr 02, 2018 | Kodak Cameras
What is the default setting numbers to get a good picture on a 42 inch ilo
Hi Darlene, Good picture is the one which is pleasing to watch and comfortable to your eyes. Please go to picture setting menu and set the levels of contrast, brightness, colour, sharpness and backlight to your liking. If you find it difficult, please go to picture MODE and select the one you like from standard, vivid, soft, and cinema. Happy viewing.
Apr 01, 2015 | iLO Televison & Video
Somehow our picture became HUGE! So huge the picture doesn't fit the screen. I can't find the remote. I there a way to minimize the size of the picture without the remote?
It will be very difficult to explain how to do it without a remote so, instesd, buy a universal remote control available at drug stores, etc. Then you can go into the TV menu and setup and define the picture size.
Dec 31, 2012 | Televison & Video
How to replace busted focus tube
They must have meant picture tube, a rear projection set has three picture tubes. One red, green and blue. One tube cost probably $150 - $250 and are not that hard to change but doing the necessary convergence adjustments can be difficult especially if you have not done them before. One thing that always makes it a difficult decision is when you put one new tube in will the other two still be in good enough condition to get a good color balance.
Feb 29, 2012 | JVC HD-61Z575 61" Rear Projection...
The picture rolls and seldom stops which makes it difficult to take pictures.
In most cases the flex cable to the flip out panel fails and needs replacement. I repair these for $200 including ship back to you if your in the lower 48 states. Larry's Electronics ledstiles@hotmail.com 916-362-8708
Apr 21, 2010 | Sony Handycam DCR-SR82 Camcorder
I have a Mitsubishi CT-21A5STX television and one of the colours has gone missing - I think it is the blue. The picture has a yellow tint to everything. Can I repair it?
Actually the procedure of this fault to check and find the cause is bit technical and difficult and can only perform by an expert, Because the problem could be the CRt(picture tube) or in circuit and both are difficult to finalise, therefore i would advise you to please contact any expert nearby,
Hope you will understand my saying.
Thanks for using fixya.
Jul 24, 2009 | Televison & Video
I turned on my LG flat screen tv and it went on and then the picture immediately disappeared but it still has full volume, however, no picture
these have been known to have leaky caps in the power supply to cause this problem, this is a difficult repair so i would call for a lg serviceman
Jul 09, 2009 | LG 42LC2D 42 in. LCD HDTV
Getting my music and pictures onto my laptop from my phone and vi
Software CD's can be difficult to understand sometimes. Good news is if you dont understand how to use the included programs, you do have a microSD card that your device has. If you have a memory card, you can store your music (no ringtones) and pictures/video onto your card and transfer them to your laptop which should have an SD card slot. Just make sure that on your memory card you insert into into the microSD card adapter which came with the phone and be sure to label folders on the card. The folders should be AUDIO (for full music), IMAGE (for pictures), and VIDEO (for video files). Then you drag and drop the file to the specific folder.
Dec 17, 2008 | LG Secret ? KF750 Cellular Phone
LCD MONITOR ACER LAPTOP TRAVEL MATE 630 SERIES
FIRST TRY RESTORING YOUR COMPUTER WITH THE RESTORATION DISC THAT CAME WITH YOUR PC (THIS WAY YOU RELOAD ALL DISPLAY DRIVERS & software like itc was from the manufactuer
Nov 19, 2007 | Acer TravelMate 290 Notebook
No Picture or Sound
Hi! Kilrm,
Servicing this set can be difficult at best, and should be done by a qualified service tech.
Toprol
Nov 15, 2007 | Philips 55PW9363 55" Rear Projection...
Nikon Coolpix L120 Digital Camera 14.1mp 21x black 26253 Logo
851 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
