Question about West Bend 56660
Coffee machine doesn't work
I cleaned this coffee maker today. And reuse it. But no steam, no heat and no coffee. Would you pls help figure out the problem?
    Problem Solver:
  • 18 Answers
Is it plugged in, b.s.? j/k, it's probably a switch that needs replacing. check the basic things you need to do before reuse after cleaning. make sure the elect.outlet you plugged into is working (maybe try another outlet?) seems like a power supply problem; a blown/bad switch could effectively cut off power to the whole unit. good luck!
Posted on Jan 11, 2009
Coffee water dosen't come out
if i'm not mistaken its the steam that's coming out not water. possibly your heating element is dead, and not heating up water to the right temperature in order to turn it to steam.
Dec 10, 2013 | Coffee Makers & Espresso Machines
Why does my DGB-300 grind coffee but doesn't brew?
having no idea where it get water from does not help us figure it out , would suggest checking with the manufacturer's website for technical support .but 15 years is a good long life . some burn out in only 3 or 4 yrs
Sep 17, 2017 | Cuisinart DGB-300 Coffee Maker
Steam wand doesn't work on sunbeam cafe series coffee machine
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Sep 11, 2012 | Sunbeam Cafe EM6910
Seaceo magic delux. Steam nozzle gives water and steam (just about) the machine makes a very loud drilling noise while trying to serve the coffee. Coffee is ground and moist when put in dispenser as it...
Please explain problem better. Whats this " just about " when you describe water and steam. Also on this cut off point that machine is getting hot . This machine gets hot normally , there is a heat cut off mounted on boiler but you would have to remove top off machine and physically check which I don't think you did.
Aug 06, 2009 | Saeco Magic De Luxe Espresso Machine
No steam
Is the coffee hot or cold?
If hot then the steam wand is clogged, try inserting a paperclip in the hole(Remove the parnello black plastic covering silver steam wand) at the end of the nozzle.
If cold then the element is not heating, if you remove the top panel on the machine there is a thermostat on the boiler. That might be damaged, some of them are resettable (it will have a red or brown pin in the middle) if it is a resettable one then push in the pin, if not then it will have to be replaced.
May 17, 2009 | Gaggia Classic Espresso Machine
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Steam generator
hard water build up in steamer tubes a good clean with clr should help remedy this make sure maker is completly cleaned after using clr cleaner
May 15, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
West Bend 56660 Logo
260 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
