Question about Epic A30T Treadmill
Turn off safe zone
I have an epic a30t treadmill and we need to turn off the safe zone to operate in the tight space we are putting it, can you help me?
  • 40 Answers
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
Posted on Sep 29, 2009
Robert Braun
  • 77 Answers
SOURCE: how do I adjust the tracking epic t 40 treadmills
If you mean side to side tracking, there are Allen bolts at the bottom rear of both sides of the treadmill. Turn one slightly one way and the other the slightly other way until it's right.
Posted on Mar 15, 2010
  • 218 Answers
SOURCE: treadmill sticks on my Epic Treadmill
replace the drive belt
Posted on Aug 13, 2010
ercupa190
  • 12223 Answers
SOURCE: How to connect Epic A30T to Ifit
Dear Sir: Will be a Great idea that you connect with the next LINK and contact them.
http://support.ifit.com/home
or You can download FREE your instr. manual and follow the steps very easy. go to www. fitness.manualsonline.com
God bless you
Posted on Dec 07, 2012
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
The treadmill turns on and has power to the upper; however, none of the buttons will work, save the tv buttons, and neither the belt nor the incline will turn on.
1) tight the upper and lower connectors and clean it.
2) tight the ribbon cable inside from display board.
3) adjust the reed swith, see the diagram attached.
4) test the power supply for display board +5 or 343cbf29-84cf-46b0-8fce-560ab4e83225.gif12vdc
God bless you
Nov 03, 2013 | Epic View 550 Treadmill
SPEED OF TREADMILL ACCELERATES
please RUN the software calibration go under the HOOD motor and see the instruction, for easy diagnostic and fix it.
God bless you
Jul 10, 2013 | Epic A30T Treadmill
My treadmill will not connect to wifi.
go to https://www.ifit.com/install
install that update and try again, this will be fix it.you will need adobe go
http://get.adobe.com/air
God bless you
Jan 14, 2013 | Epic A30T Treadmill
God bless you
Dec 07, 2012 | Epic Exercise & Fitness
Console epic 550 treadmill
adjust the REED swtich, test it for open or faulty, clean it , and tight the plug very well. see the diagram attached.
Plug the ribbon cable for keypads very well, and clean it.
God bless you
Dec 02, 2012 | Epic View 550 Treadmill
Does Epic 425 MX parts can be removed? I cannot move the Treadmill in to my house due to too bulky for any door. Help!
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free
from www. fitness.manualsonline.com
God bless you
Nov 18, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Turns on but will not respond when keys are pressed
Dear Sir:
As you must understand the treadmill use the most advance electronic design.
Please do the following:
1)use contact cleaner(radio schack or whatever)
2)Inspect the fuse.
3)Tight the ribbon cable INSIDE from the keypanel(not the console)
4)Tight the connector from the console going to the main board motor.
check this block diagram for to see if anything can help you in the treadmill. If you do not resolve your problem. can be board console vs . main board motor.
2_14_2012_7_36_06_pm.gifGod bless you. sincerely.
ernesto a cuadra
managua, nicaragua
Jan 09, 2012 | Epic 450 Mx Treadmill
Epic A30T Treadmill Logo
91 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
