Question about Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The power cord no longer retracts. How to I take the machine apart to get at and fix the power cord so that it will retract?
  • 6 more comments
  • Anonymous Mar 12, 2008
    same problem, but on old Electrolux 1401-B canister purchased in 1981. Having trouble figuring out how to take it apart, and can't find manual.
  • nicola1996 Jul 14, 2008
    My electrolux cleaner system 90 has the same problem. I cannot open the body. could you explain please how it is done.
  • uschews Nov 21, 2008
    similar to guest March 12, 2008 I am having problem with Electrolux model 1401 canister vacuum . Retractable wire cord not retracting and cord is stuck all the out - cannot figure how to remove canister to retract cord and to reset . Also cannot find manual . Need help or suggestions .
  • Anonymous Mar 12, 2014
    power cord is stuck in machine I have a retractable cord
  • Anonymous Mar 15, 2014
    The cord wont retract otherwise the machine works well.
  • Anonymous Mar 16, 2014
    power cord won't retract
  • Anonymous Mar 25, 2014
    The cord on the vacuum does not retract. How can we fix it?
  • Anonymous Mar 30, 2014
    The cord won't retract
  • 625 Answers
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Posted on Aug 20, 2007
  • 262 Answers
Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You coould try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
Posted on Sep 02, 2010
Does anyone know where to purchase the electrical cord and cord reel for Electrolux 1401-B canister ? Thanks
Posted on Aug 07, 2008
I own an electrolux ambassador III i spent a lot of money on it and if it broke it i would take it to an authorized electrolux repair shop because it sounds easy to fix them but electrolux vacuums have a complicated wire system and it is easy to mix them up or break is worse then it is to begin with.
Posted on Jul 26, 2008
I have removed the rubber side coverings on mine but can not get the plastic to slide out. What am I not doing?
Posted on Feb 06, 2008
Cord retraction
You may have to replace the cord reel. First inspect it thoroughly to see if you can find something restricting it from retracting.
Apr 15, 2018 | Vacuums
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Electric cord will not retract
I found the solution from another web site. Removed the reel coil, cleaned it of lint, etc. replaced it and it is now working. Thank you for your relpy
Jun 26, 2008 | Vacuums
Retractable power cord
JUST LIFT OFF THE TOP HALF. CAREFULLY REACH IN FROM THE LEFT SIDE AND DISCONNECT THE CLEAR PLASTIC HOSE THAT IS ATTACHED TO THE "DIAL" ON TOP OF THE MACHINE. THEN LAY THE TOP HALF OF THE MACHINE TO THE RIGHT. DON'T DISCONNECT ANY WIRES. YOU'LL HAVE TO HAVE A NEW CORD WINDER (LOOK ON E-BAY). THE MOTOR AND CORD WINDER ARE ATTACHED TO EACH OTHER BY WIRES AND CAN BE LIFTED OUT OF THE CANISTER.EVERYTHING YOU DO JUST REMEMBER THAT ALL OF THESE PARTS ARE ATTACHED TO EACH OTHER BY WIRES. THE ONLY WIRES YOU'LL NEED TO DISCONNECT ARE THE ONES ATTACHED TO THE CORD WINDER ASSEMBLY. THEY JUST PULL OFF, NO TOOLS ARE NEEDED.
QUITE FRANKLY THIS IS A ROYAL PAIN AND YOU'LL PROBABLY WISH YOU TOOK IT TO A REPAIR (AERUS/ELECTROLUX) SHOP. IF YOU DECIDE TO DO IT YOUR SELF TAKE PICTURES OF EVERY STEP...'CAUSE YA GOTTA PUT IT ALL BACK TOGETHER.
GOOD LUCK!
Sep 08, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
4,966 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
