Question about Saeco Odea Giro Plus Coffee Maker
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the steamer about 30mls of water goes into the milk.
  • gloria_at Jan 12, 2009
    Cant remove the frother, will not budge. Thanks for the info about the steam, that worked
  • gloria_at Jan 13, 2009
    I took my machine to a Saeco repairer, and the problem was a solonoid it had to be replaced. The frother was fine
  • 2,039 Answers
Try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Posted on Jan 11, 2009
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
No Hot Water when you press the button
I uploaded a file on descaling your machine at this site groups.google.com/group/espresso_worlds moz-screenshot.jpg
Mar 20, 2009 | Saeco Royal Professional Espresso Machine
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
There is probably something wrong with the milk frother. I would purchase a new one before having the machine serviced.
http://cerinicoffee.com/cappunicatore_Royal_white.asp
Apr 30, 2007 | Saeco Royal Professional Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
574 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
