Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Connecting the cable coaxial cable to a P50HDM VIZIO TV
I am having a difficult time trying to find the coaxial connection on the TV mentioned above so it could be connected to the cable coaxial from the wall.
  • Anonymous Mar 10, 2009
    I cannot find the coaxial cable connection, either. Anyone? I will be calling vizio tomorrow monring.
    New Friend:
Yea wtf same prob here just want to put a indoor antenna now I got to go buy an external receiver booooooo!
Posted on Aug 01, 2015
4 Suggested Answers
SOURCE: the sylvania plasma tv does
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Posted on Oct 18, 2010
Bhatcher5127
  • 6 Answers
SOURCE: connect to coaxial cable in wall
You have BNC connections on your TV you need a BNC to Coax adapter sold at any AV store and sometimes radioshack.
Posted on Sep 09, 2008
jan mczeal
  • 632 Answers
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Posted on Sep 26, 2009
I own a Vizio 42" flat screen tv, model number M421VT and every time I plug it in, the Vizio logo at the bottom begins to blink white, it will do that for about a minute and then the symbol will appear on...
Check for signal input at the HDMI port or Coaxial connection. Check your cables or try a different one. Be sure your signal source is handshaking with the TV set.
Mar 29, 2015 | Vizio Televison & Video
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Dec 08, 2014 | Vizio VO320E LCD TV
How to put coaxial cable in harman kardon
A coaxial cable is the name given to a digital cable that appears identical on its connectors to an RCA cable that is designed for analog signals; however their resistance measurements are different.
On the receiver you are asking about, the input and output terminals are labeled as coaxial and are colored orange. These are single cable connections. Power off the unit, and also turn off the device you want to connect the receiver to. If you are connecting a device such as a DVD, CD or Blu-ray player to the receiver, look closely at the cable sheath. You will see an arrow on it. That arrow must point at the RECEIVER coaxial INPUT if the other end of the cable is connected to one of the devices just mentioned. Make identical connections on each end pushing the pin all the way onto the terminal until it stops; coaxial connections are typically very tight. If it is too difficult to fit, putting a dab of contact grease or tuner cleaner onto the connector will help.
Feb 21, 2012 | Harman Kardon AVR 130 Receiver
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
Need help connecting to surround sound to a vizio sound bar
hi,
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
ok
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have a Vizio P50HDM which will seem to turn on but It displays a small blue rectangle in the center of the screen with the message: "No Signal" I have tried pressing the input button but same message....
Your TV isn't detecting a signal on any input. You can have a bad connecting cable, or a defective source unit, (cable box, satelite reciever, DVD player....). Those are just a couple of possibilities, but a good place to start. Good luck.
Dec 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I can find where to conect my antena cable on a Vizio p50hdm
Your TV is a monitor only. That means it does not have a tuner inside for an antenna. You may try a VCR for a tuner and hook up the antenna to that. Good Luck
Jan 24, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
42 in lcd vizio "no signal"
if the TV have a no signal sign which means most of the important part is missing. Try checking your connections. The best way is to hook up a dvd player using AV input (the yellow, red and white). make sure that you turn the device on and whatever input you connected the device to is selected. if your TV is a P50HDM model, the TV will shut itself off after a short period without and input connected.
Sep 08, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
1,370 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
