Question about Whirlpool Dryers
Whirlpool Duet WED8500 is making a loud squeaking when it is turned on
Turning on my dryer it will start this high squealing sound
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
  • 221 Answers
SOURCE: Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Posted on Mar 11, 2009
  • 132 Answers
SOURCE: dryer making loud squeaking noise
Replace all the drum rollers.
Posted on Mar 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: dryer squeals when i turn on
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 01, 2009
Testimonial: "very through info. thank you"
TheMobilian
  • 8220 Answers
SOURCE: squeaking when running
Repair pix
Posted on Jan 21, 2010
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet GEW9250PW1 electric dryer squeals
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Squealing noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer squeaks very loud.A loud constant squeak
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 15, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
