Question about RCA 20F420T 20" TV
How to make a drivingway for my garage of my new house.
I have a new house. I am going to make a driving way between the street and my garage with bricks.
Can anyone tell me what stteps I should follow?
thanks!
  • 1,498 Answers
Hey Paul,
I'll give you the rundown. First, for a driveway, I'd have to advise using a pretty thick slab of concrete beneath the brick. The concrete part of it should be done professionally. But I live in an area with lots of rain (hence, Mud), might not be a problem where you are. Anyway, here you go:
  1. Clear the area so its smooth. Grade it if necessary.
  2. After clearing the area, set the perimeters with string or with 1x4 boards. This keeps you from going wide as you lay the bricks
  3. Get a load of sand and spread it evenly over the area. This can be done easier with two people and a long 2x4. The depth should be at least an inch. This makes leveling the bricks MUCH easier. Keep some aside for filling in the spaces between the bricks. Keep it dry too.
  4. Start at one end and start placing the bricks. As you advance, you'll be on the bricks, not the sand.
  5. Have a straight edged board handy to level them. Use a rubber mallet to tap them down. Consider the spacing between them. Use a scrap of 3/8 wood or something like that to keep the spacing consistent.
  6. As you place more bricks, get up occasionally and eyeball your work.
  7. After they are laid, you'll need to hit a home improvement place. You are looking for a glue (powdered) that is mixed with your left over sand to set the bricks. Ask someone there, they will know.
  8. You mix it in with the sand and dump it in the middle of the bricks. Then just sweep it over the entire area until the spaces are filled. Then sweep off the excess.
  9. Once filled, lightly spray water over the whole drive. This activates the compound. Once dry, you have a driveway.
If you do concrete it first, you'll only need enough sand for the space fill.
Hope it turns out great. I love brick drives.
Mike
Posted on Feb 12, 2009
  • Justin Case
    Justin Case Feb 13, 2009
    Hey there Paul,
    Did you know I'm a volunteer here. The only compensation I get are ratings and the satisfaction of helping people that need it.
    You may not understand the rating system, but I've got to ask, Why only a helpful rating and not a FixYa? Short of laying the bricks myself, what more could you want?
    You've been posted for a month without a nibble, mainly since you chose to categorize your masonry problem as 20" RCA television. You type two sentences to describe what you want. Two minutes max investment.
    Then I stumble across it and feel sorry no one picked it up even if you did miscategorize.
    In response, I give you a full page of well thought out professional step by step details as well as time and money saving advice, not to mention the 45 minutes of my life it took to put it down, all of which cost you and made me nothing.
    To show your gratitude, without any comment as to why, without a syllable of interaction, you take the time to give me a rating which lowered my overall rating by a full point. I can't thank you enough.
    I'll be thinking of you while earning my next five FixYa ratings trying to get my score back up to the break-even point it was at before I ignored my better judgement and responded to your lost post.
    It would have been better if you didn't rate at all, at least then you wouldn't have done any damage. I guess no good deed goes unpunished.
    I'm usually more diplomatic than this, you probably meant no harm. But that doesn't make it right. At least I'll get the Positive Karma points for my part.
    Sorry your Karma is counterbalancing on the negative side of the scale, especially with today's date falling on a Friday. Bad timing. You're the only one that can undo it.
The frequency of the garage door opener is the same as the one down the street. Is there a way to change frequency on the Lift-Master Professtional Line Garage Door opener?
This appears to be your problem.Your door sometimes is opening unexpectedly and inadvertently when a seen or unseen neighbor uses his or herremote door opener; or a neighbor wonders why his/her own door always seems to open shortly after you drive by; and you wonder if her and your remotes should not be transmitting each at its own unique frequency level. Or in the worst case, someone, possibly a prankster, possibly someone more nefarious, is driving through neighborhoods punching a remote to see if any garages respond (and if any indoor occupants respond).
Its transmission radio frequency is not what sets one garage door remote apart from any other. Instead, each door remote controller transmits in rf adigital codeinto the air near your house, and any door opener power head set to the same code recognizes the code and is commanded to energize its power head motor to raise or lower the attached door in reverse of its last most previous transport direction. The chance, probabilistically speaking, of any two near-neighboring houses' garage doors (or even a random, travelling remote) being set at the exact same code among the large number of available alternative codes is quite remote, but it can sometimes happen.
The solution is for the house owner--that is you-to change the reception code in your door opener power head unit by repositioning small selector contact switches in a code pad situated on the power head, typically behind a plate or cover of some kind--or you might have to remove the power head cover. Once found, it is fairly easy to do by setting the numbered or lettered switches to form a multi-digit code, much like a digital padlock combination except in binary or some base other than decimal. Next, record the new code, and change the code by the same means and method on all associated remote control instruments. It is not a bad idea to change garage door remote access code from time to time simply as a matter of routine garage door and door opener maintenance. Check for code switch location and setting procedure for you power head in user manual or on line. That should be the end of the problem and also discourage anyone casing your neighborhood for potential unlawful entry vulnerability.
Feb 18, 2015 | Building Materials
Audi a6 quattro 2001 coolant disappears, engine overheats and white smoke comes out
Unfortunate you're losing coolant into the cylinders, where it's being burned off and exiting out the exhaust. When you initially added that cold coolant into the hot radiator, and hot engine (sit down) you likely cracked the engine block. Best case you just need to replace the head gasket.
Jan 07, 2013 | 2001 Audi A6
Wiring in a remote motion sensor to existing lights
yes it can be done and they are on the market from regular hardware retailers and security specialists
they come as a complete diy box with the light/movement sensor and a light fitting
the sensor "sees" daylight and turns off the unit until the lux reading drops then turns on the light
on off is controlled by the setting that you make on installation
motion then turns on the light and the period that the light remains on can be set by the knob adjustments
Average cost starts around $25.00 aud up to $100.00 aud depending on quality
normally they have only 1 light of 100 watts included in the box but they will run successfully on 15 watt fluro bulbs because all that is wanted is light and a 15 watt fluro bulb puts as many lumens ( light measurement) as a 100 watt bulb
if you want to run more bulbs of higher wattage , talk with an electrician about putting a relay after the sensor so that the current flow through the sensor is reduced and allow it to operate better and longer
Apr 21, 2017 | Kitchen Appliances - Others
The remote for my garage door only works on weekends.
Monday through Friday look at the LED on the rear of the motor unit. If it is flashing rapidly you have radio interference. See if you can locate the source. It will be something electrical - maybe a military base if nearby.
Jun 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: There was a transformer explosion in the street, ...
There is no fuse in your opener. The logic board is very susceptible to power surges. You can pull it and check for burnt or missing traces on the printed circuit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Harsh shifting
i would honestly recommend going to a dealership, your problem is definitely in your transmission, and that wouldn't set off a check engine light
Jan 29, 2009 | 2008 Chrysler Pt Cruiser
RCA 20F420T 20" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
