Question about Home
I need a shower curtain rod that won't rust/corrode
For rods that won't rust you might need a rod made of stainless steel or even nylon. This site sells these type of shower rods:
http://www.showerrods.com/
Posted on Dec 21, 2012
  • 2712 Answers
SOURCE: How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Posted on Aug 27, 2008
feragola
  • 24 Answers
SOURCE: Polder Duo Shower Curtain Rod Instructions
Cindy,
This might help you out.
http://common.csnstores.com/common/marketing/uz1194manual.pdf
Feragola
Posted on Nov 24, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: I broke one of the hooks of my shower curtain.
Here's a good start:
http://www.showercurtainsgalore.com/shower-curtain-hooks-&-rods/4637+4640.cfm?source=overture&kwid=shower%20curtain%20hook
-Tha Mp3 Doctor
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: shower grab bar has rusted
u could always repair the rod, its cheaper and easier, first of clean the rust off with viniger, white works best, then go buy some enamel paint, a small jar of whatever colour it is make sure its water prof, i suggest u do this in the morning then it will be dry for u to use at night, and there u go, if ur lazy however spend the money and change the bar, gd luck!
Posted on Apr 12, 2009
  • 260 Answers
SOURCE: Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Posted on Apr 14, 2009
TENSION SHOWER CURTAIN ROD INSTALLATION
Extend the rod until it reaches both sides. Hold one side of the rod while turning the other end until it expands and has tension. Good luck!
Oct 30, 2016 | Home
How do I get a retractable shower rod to retract once it has extended?
Sometimes these things can have very stiff springs in them. it may not be locked in place. you may just need to have someone hepl you. Try putting the rod in a corner, (floor preferably) and push on it using your body weight. It is alot easier to put the nessary pressure on it when you are not working above your head.I think you just need help putting it back in.
Sep 12, 2012 | NRS Strom Plumbing Neo-Angle Corner Shower...
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Jul 30, 2010 | Rocky Mountain Hardware Shower Curtain Rod...
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Cindy,
Feragola
Nov 22, 2008 | Home
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Home Logo
909 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
