Question about Karcher 2500 PSI Pressure Washer
Pressure washer repair - Karcher 2500 PSI Pressure Washer
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
Durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Aug 12, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
Karcher 2500 PSI Pressure Washer Logo
69 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
