Question about Mr. Heater Big Buddy Heater
Mr heater big buddy will not light
5 Suggested Answers
SOURCE: Mr Buddy Heater Flameup on ignition
It sound like the pivot inside the regulator is damaged. I think that you will need to replace the regulator.
Posted on Jan 05, 2009
  • 115 Answers
SOURCE: my big buddy heater has sat all year and now it
you may have cobwebs in the gas orifices. shut off gas and power then poke each hole out with a wire turn on gas and power and try again
Posted on Dec 13, 2009
kapishtech
  • 2272 Answers
SOURCE: Mr Buddy portable heater Model
Turn the valve counter clock wise to open in and clock wise direction to close it.if its got stuck on any position,then move it on both direction and then move counter clock wise to open the valve. Check out.Keep updated.Thanks.
Posted on Aug 31, 2010
  • 125 Answers
SOURCE: when I press down and
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Posted on Sep 16, 2011
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
The on & off switch for the fan----the switch on or off which position is correct
I have the "Big Buddy" heater and the switch is on top, if it is clicked down toward the front of the heater, the fan is on (little yellow dot), pushed back, the blower is off.
Nov 06, 2015 | Mr. Heater Mr Heater Portable Buddy...
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
CAN YOU USE A BIG BUDDY PROPANE HEATER INSIDE A TRAVEL TRAILER.
Yes you can use it.... BUT!!!!
make sure all combustibles are at least three feet away from the heater....
AND...open a window a bit... 1-2 inches... to allow fresh air in so you do not get CO poisoning...
heatman101
Dec 25, 2010 | Mr. Heater Big Buddy Heater
Big buddy heater caught on fire
HI try mr heater wed site there has been some recalls on these heaters , it sounds like you had too much pressure going to the heater , or the gas valve was faulty, hope this helps
Feb 09, 2010 | Mr. Heater Big Buddy Heater
No propane comes thourgh pilot on mr buddy heater
If the pilot will not light get a q-tip and alcohol and remove the wire grill and be sure the cotton doesn't come off the end of the stick wet the cotton with the alcohol and twist it and push it down into the pilot tube 2 full inches. Let the alcohol soak for 30 seconds and while twisting pull the q-tip out. Try this until the pilot lights.
Jan 01, 2009 | Mr. Heater Mr Heater Portable Buddy...
Mr Heater 1500 propane heater malfunction
How about the thermocouplin have you tested that?
Jan 31, 2018 | Mr. Heater Mr Heater Portable Buddy...
Heating & Cooling Logo
340 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
