My washer is showing the code F32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned.
Be sure you are using H.E.(high efficiency)detergent.
Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains you will need to call for service.
This type of repair will require accessing the inside of the cabinet area to make some checks.
This will require a service technician to diagnose & repair.
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
f32 error code
