Question about LG Refrigerators
LG model LFD22860ST refrigerator door cam and gasket holder installation instructions
Need instructions on replacing door cam and gasket holder
  • 72 Answers
SOURCE: door gasket repacemrnt
call marcone appl parts they will ship it to you give them mod #
Posted on Jul 05, 2009
erpaalai
  • 999 Answers
SOURCE: replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
Posted on Oct 21, 2009
rulds2008
  • 3866 Answers
SOURCE: I have an LG Smart
These people below sale them
http://www.appliancepartspros.com/partsearch/
Posted on Sep 21, 2010
  • 489 Answers
SOURCE: Refrigerator light not working before fail light
If you have checked the light switch and found it to be working normally, then you will need to replace the control board because the light bulb is controlled by the relay switch. It is not directly connected to the light switch. Good luck
Posted on Jun 19, 2011
Daniel S
  • 4323 Answers
SOURCE: I have a model LFC23760/SB01
Hi
Please check this link to download the service manual for instructions. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 30, 2011
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
My LG model LRFC25750TT french door gaskets are shot. Any tips on (a) where to order new ones (L & R); (b) how to remove old ones; (c) how to install new ones -- screws to take out or not, tools...
Ok the gaskets should be press in type. No tools just a hairdryer to take out any wrinkles from shipping. And just go slow dont stretch too much. And you can buy from sears parts driect. Just have your model number ready. I hope this helps.
Aug 23, 2011 | LG LRFC25750 Refrigerator French Door
Refrigerator light not working before fail light started to blink when the door was opened - contacts on door switches OK - believe it to be poor contection - reading low voltage - looking for schematics...
Jun 19, 2011 | LG LFD22860 Bottom Freezer French Door...
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
Freezer door pops open on Whirlpool Model WB FNGF V000
Good day,
If the gasket on the freezer door mates properly to the cabinet, and the door pops open when the main door is closed, then it means the magnets embedded in the freezer door gasket, have become weak.
One thing you can do, is elevate the front of the machine slightly, and place items of weight in the door itself.
Failing that solution then.......
You will need to replace the gasket.
It should be available at most appliance parts houses.
Ask the counterman for instructions on installing. If he's good he will give you explicit instructions on how to replace the gasket.
Follow those instructions, because if the procedure isn't followed, the door may become warped, and will not fit properly.
Dec 14, 2009 | Refrigerators
I need a part number
google this part number 5231JA2006B
Dec 01, 2009 | LG LFD21860ST Stainless Steel Bottom...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Refrigerators Logo
55 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
