Question about RCA HD52W140 52" Rear Projection Television
When Turned on screen turns bright the TV turns off a few seconds later
No one seems to know what the problem is. I have sent my RCA HD52W140 (ATC311A chassis)4 times and had $1,000 in replacement parts (under warranty at time). It still has problems. When I turn it on I have a great picture. After a few seconds the picture turns bright red and then shuts off. I pulled the CRT board and swapped it with the blue and the green CRT boards. The problem then moves to the CRT I moved the board to. All of the CRT's appear good since when i swap the boards the only one that turns bright is the one that has the board in question. I tried to get a replacment board but RCA doesn't make the part anymore. Instead I had to send back the board to be rebuilt. When I got it back the same problem was there. It has to be something about the board. Is there something I'm missing? Nobody seems to have a solution. I have been trying to figure it out for about six months. I have already replaced the tv. But I hate not being able to figure this out. My parents originally owned it then gave it to me after they replaced it.
  • 2 more comments
  • Daniel Moody Jun 07, 2007
    1. Replace R14705. Also check HV splitter and deflection board components.
    2. Check connections at C14703.
    3. [Crack in HV splitter] Replace resistor and check Q14401.
    Does anyone have a diagram of these.
    The HV splitter has been replaced and still looks good. If the HV splitter was bad wouldn't it affect any board in the same position? The problem always follows this one board.
  • Daniel Moody Jun 08, 2007
    "Ok what you need to do is to swap the drive wires from the bad board with another good board. swap every wire except the larges wire going into the crt socket. this will eliminate the board if it follows the drive wires to another board."
    I need this in laymans terms. All of this advice sounds good, but I need it in terms I can understand.
    None of the wires are soldered to the board. There are four wire plugs. 2 ribbon cables(one 16 wire, one 6 wire. One 3 wire plug(one to GND, one to focus screen box, one to wire strap around CRT. One 2 wire plug(grn and wht wires attached to tube at bottom of CRT. And then the focus wire attached to CRT socket. I have disconnected all plugs from the board in question and moved the board to a different CRT and reconnected the plugs from the CRT i moved it to onto the board I swapped. The board was on the red CRT. Now it is on the blue CRT connected to all the wires for the blue CRT and the problem is now with the blue CRT. The red CRT which now has the board from the blue CRT is working fine now.
    I understand what you are saying about leaving the board where it is and switching just the wires from a different CRT board with it. But do I switch all of the wires or just the 3 wire plug and the color spacific 6 wire ribbon cable? If it helps the part number on the board is 258504.
  • 944 Answers
If this problem is still unsolved, I believe the problem may well be a grounding issue, possibly in the power supply, but more likely in the two boards that do not fire up, maybe a broken PCB track or solder joint, possibly a through-board grounding screw that is incorrectly installed. If you could take a picture installed, and uninstalled front and back of one of the boards and post it back we could maybe get a clearer idea. Hope this helps :)
Posted on Aug 15, 2007
    President:
  • 3,130 Answers
Ok what you need to do is to swap the drive wires from the bad board with another good board. swap every wire except the larges wire going into the crt socket. this will eliminate the board if it follows the drive wires to another board. Your problem could ten be from the focus screen pack, that is the block with all the three focus controls and the screen controls on it.And if you swap those screen wires, and still have this problem you will have to check the RGB voltage at the video jungle IC. Good Luck
Posted on Jun 07, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jun 08, 2007
    OK, what you need to do, is take the bad board, mark where every wire goes disconnect the wires, take the blue board and take thoise wit=res and solder them to the red board and then the wires that were on the red board solder to the blue board. But leave the boards at their proper place, ig red board on the red cRT but has the blue wires attached, and the blue board on the blue CRT but has the red board wires attached. Then if the problem follows to the blue tube, you know the problem is in the screen or RGB drive circuit. If the same red tube has a problem, someone did a lousy job fixing your board.
  • Larry  Dillon
    Leave the board and change all of the wires
  • Larry  Dillon
    Larry Dillon Jun 09, 2007
    all of them
    Sergeant:
    Champion:
  • 326 Answers
Hello, actually there can be a few solutions. 1. Replace R14705. Also check HV splitter and deflection board components. 2. Check connections at C14703. 3. [Crack in HV splitter] Replace resistor and check Q14401. If this does not help, please advice. Best regards, Arpi
    Genius:
  • 1,074 Answers
There are some transistors on the board that reads good when tested but under load they fail replace all of the transistors and diodes that will take care of your problem.good luck.
SOURCE:
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Dec 02, 2012 | RCA HD56W58 56" TV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
White screen, no sound
Are you still accessing menu? Can you connect your PC to TV and see a signal?
Jan 25, 2018 | RCA F19420 19" TV
Tv problem rca F19431
INTEGRADO DE AUDIO RCA F19431
Jun 07, 2008 | RCA F19431 19" TV
Tv problem dead set
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
http://servicemanuals.vstore.ca/
May 20, 2008 | RCA HD52W140 52" Rear Projection...
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
I have a rca hd52w140
Does the unit show a flashing led on front panel. make any sounds. reset this tv if it works invloves unpluging the set for 30 minites.
Oct 16, 2007 | RCA HD52W140 52" Rear Projection...
RCA HD52W140 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
