Question about Wireless Computing Computers & Internet
Ge mouse 99914 stopped working - Wireless Computing Computers & Internet
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: how to insert batteries in 99914 mouse
Install the batteries (2 AA batteries) into the mouse. Locate the red laser light underneath the mouse. Next to the light, there is a small button that will require a small object, such as the end of a pen, to press. Press and hold this light for 3 seconds. You should observe several flashes of red light and then a steady red light when it is ready
Posted on Nov 19, 2011
Well, whomever posted a solution was incorrect with my mouse. Right underneath the mouse cover there is a battery compartment, that holds the two batteries in place. To remove that cover you will need something to pry lightly on the lip clip pushing it forward toward the wheel. Remember just a little pressure otherwise you could damage said mouse. The clip is toward the back right above the batteries. good luck
Posted on May 07, 2013
99914 ge
see if the pc recolonize it when you plug it in it should if not you may need to reload the drivers manually.
May 25, 2014 | GE Wireless Optical Mouse
GE Wireless 2.4 GHz Mouse 99914 can't get batteries in it
Right below the storage compartment for the USB Nano receiver is a small lip clip. You can try to light it up carefully with your nail or a small tool and the whole plastic piece holding the batteries in place will lift up. You then will be able to insert the batteries. Remember this is a plastic piece so it can break easily. Hope this helps.
Apr 01, 2013 | GE Wireless Optical Mouse
Ge wireless optical mouse 99914
In this case, I think GE may stand for "Gratuitous Effort" (Required). I'm unsure why they made this so complex. Luckily, by some miracle I saved the instructions.
Here's how to do it.
  • At the base of the mouse (nearest your wrist), you'll see a small rectangular tab. Push down on it, and slide the cover off the top of the mouse. If your mouse is colored this is the top colored portion that slides free.
  • You'll see the two batteries, trapped under the Plastic Holder of Death (P.H.D. for short). On the side of the P.H.D. closest to your wrist, look for a very small rectangular tab. It is right in the middle, in the ditch between the batteries, and rests on top of a small circular indentation/ lens thing.
  • On the other end of the P.H.D, just below the mouse wheel, you should also see a larger plastic latch holding that end in place. The key is to push in the small rectangular tab while, at the same time, lifting the latch. The tab doesn't want to move, and this is tricky to do with just two hands, so what I did was:
-Use the tip of a pen to press firmly on the plastic tab. It doesn't seem to want to move; personally just my finger pressure didn't do it, although if you have fingernails it might work for you. But the pen helped me push harder and also was easier to do one-handed.
-While you push with the pen, use the other hand to slide a fingernail into the latch on the other end of the P.H.D. Push the latch back (towards where you're holding down the tab with the pen), while at the same time lifting up. The tab being pushed down will cause this latch to free, and you should feel it come loose. Then you can simply maneuver one or the other end of the P.H.D. out. The tab will eventually pop free, and your batteries will once again see the light of day.
  • A side note: I realized that, if you do this enough times (like more than once), the tab sort of wants to pop off. This was not a disaster. In fact, it was kind of awesome, since I won't have to do this rigmarole again. The large latch on the wheel end is plenty to hold the P.H.D. in place, and you can also wedge the (broken-off) tab back in if you want an even tighter fit. Once the mouse cover is back in place, of course, it's all good.
Whew. See my Microsoft Paint Masterpiece below for a visual on this. Viva las pilas!
Jul 16, 2012 | GE Wireless Optical Mini Mouse 3087897985
GE 97986 mouse and Macbook Pro
try a hp mouse it worked for me
May 25, 2012 | GE ho97986 Mouse
How to insert batteries in 99914 mouse
Nov 19, 2011 | Computers & Internet
GE wireless optical mouse suddenly stopped working. i restarted computer and tried to reset both mouse and the receiver to no avail. also changed out batteries.
Hi, my mouse work fine since pressed simultaneously the buttons of the mouse and the receiver. Previously, I had disarm the receiver, but all was fine, so I'd arm again the receiver and plug to laptop; I'd press both buttons and mouse work. For any reasson, mouse and receiver lost conection and is necessary re-establish comunication pressed both buttons. I hope my experience (my case) to be useful to someone.
Jun 24, 2010 | GE Wireless Optical Mouse
Ge mouse stopped working , changed batteries & pressed reset still no response
Only one thing for Hardware of Mouse if wireless cheak if Reviver is Faulty and connects with Wireless Mouse and if still no respond try another reciver to see if the other wireless Mouse correctly works.If it Mouse that gone and have Garentee take back to store if your warenty is in Refunded Policy or you apply for Garentee on your Product.
Jan 28, 2010 | GE 97985 Mouse
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Jul 30, 2009 | GE Optical Mini Wireless Mouse 98793
GE Wireless Optical Mouse 98763 will not work. It
Check out the batteries on the mouse and the "reciver".
Jul 14, 2009 | GE Computers & Internet
Ge optical mouse-lights are on batteries fresh=will noy move the
The receiver (that plugs into the pc) and the mouse must be "linked".
Here is the link for my solution to this:
http://www.fixya.com/support/t2286160-batteries_go_ge_optical_wireless_mouse
Jun 26, 2009 | GE Wireless Optical Mouse
Computers & Internet Logo
24 people viewed this question
Top Wireless Computing Computers & Internet Experts
David Payne
David Payne
Are you a Wireless Computing Computer and Internet Expert? Answer questions, earn points and help others
