Question about Panasonic TH-42PA25U 42 in. HDTV Plasma Television
Cannot make a thing show on screen, no menu, no anything.
I accidenetly hit a button and cannot see the best at 75 years of age, the more I tried to re-connect, the worse it got until finally, the cable box nor tv will do anything, can you help? Screen is all snowy.
  • 362 Answers
With the cable box turned on, take the actual remote for the tv and press the imput button, you may have to keep pushing it until you find the right input.
Let me know if this helps. I can assist further. lone99star
Posted on Jan 10, 2009
  • BRUCE HERRMANN
    BRUCE HERRMANN Jan 16, 2016
    To lone99star: I don't have a cable box to plug into. I have wireless, but I have a cable line that plugs into back of t.v.
Showing only white screen
Sounds like you went into your TVs service menu and turned on Aging mode. Try pressing a button located on the TV (remote will not work), failling that, you might have to wait it out.
If you didn't come across this menu, if your still in warranty, take it to best buys geek squad and have them look at it.
Jun 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Aug 28, 2017 | Compaq FP 5017 15" Flat Panel LCD Monitor
How do you switch from 4.3 to 16.9?
try the blue button, or menu,(then a square with 2 opposing arrows) and adjust there.
I am assuming that Sony have not drastically changed button layouts)
Jul 12, 2009 | Sony KP-57WS500 57" Rear Projection...
Menu screen is black
That sounds like your video card is going out on your computer. You will have to get that replaced and then things will work properly.
Jun 10, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
Moisture detected
Take the battery pack off and hit it (not too hard) with the palm of your hand. It SOUNDS CRAZY but my own camcorder had the exact same issue and all it took was one hit- put the battery back on then powered it up- VIOLA- it works! I am not kidding, try it. You'll save LOTS of $$$$$. This is NOT a joke.
Sep 07, 2008 | Video Cameras
No Video or Sound
Hello Mabsab:
The repairs may cost starting at $ 75.00 to $100.00 for the estimate and basic trouble shooting the final cost of the repair may be about $200 to $400.00 dllars depending on the price of the part and the labor that is charged.
Aug 17, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Canon ixus 75 black screen
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!!
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Moisture detected
disconect the batery and conect again several times. wait until it shut off and repeat again. it will work in minutes.
Feb 27, 2007 | Quasar VM-L459 Camcorder
Hitachi 53 fdx 20b pojection tv
If you lost the picture and even the menu does not show up on screen, then I will bet that your high voltage has shut down or the computer has stopped the picture because it has detected a fault in the vertical circuit. In either case this is something that cannot be reset with the buttons or remote and should be handled by a qualified tech.
Oct 24, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Panasonic TH-42PA25U 42 in. HDTV Plasma Television Logo
77 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
