Question about ASUS P4C800 Deluxe Motherboard
SATA Drivers How do you get an ASUS SATA driver onto a floppy so that you can install windows XP on a SATA drive?
    Champion:
  • 240 Answers
At ysytem start up you need to acces your biose window f1 or f12 or escape or del
are comen keys to try in borem window of system at first trun on it shold tell you the key to press to acsess you biose system setup window.
after you acess this goto hard drive setup slect stst as your hard drive then your system is ready to setup.
thanks.
daniel
Posted on Jan 13, 2009
Hello when i install windows my sata hard dont detect. my main board is asus k8ux hard is western 1.0tera
You are probably installing windows XP
This requires that you install the textmode sata raid drivers as you install windows
http://support.asus.com/Download.aspx?SLanguage=en&m=K8U-X&p=1&s=20
Download the RAID driver and expand it to a floppy , CD or USB drive that the computer can recognise
(USB is better)
When you install windows, at the prompt for installing other drivers press F6 and let it find the raid drivers, if it finds them, it should then recognize your hard drive and you can install windows XP
Jul 26, 2011 | ASUS K8U-X Motherboard
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
I want to install XP Pro on a sata drive
You need to post what Brand/Model of motherboard you are using, or search for yourself on the manufacturers website for the SATA drivers. Then you need to load the SATA drivers onto a floppy disk so that you may press F6 during the beginning of Windows Setup to load the SATA drivers, as Windows XP Setup does not come with SATA drivers.
Jul 19, 2009 | ASUS MB-SK8V Motherboard
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Problem installing Windows XP with Asus P5RD1-VM series mothboard
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find, or where from i get the floppy in...
use Nlight research this software in the net and you will find the answer works on laptops too the process is called slipstreaming. the process of witch you integrate the sata driver to the xp intallation disk to provide the necessary driver you required first download the driver you need then use Nlight to integrate the driver to the xp installation disk of course you will need another writable disk to accomplish this. thank you
Nov 21, 2008 | ASUS P5RD1-VM Motherboard
How to install window XP without floppy disk on asus P5RD1-VM
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Mar 30, 2008 | ASUS P5RD1-VM Motherboard
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in bios  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
you need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Oct 25, 2007 | ASUS S-presso Standard S1-P112...
First time connecting SATA hard drive to this motherboard - do I need special drivers?
Go to the bottom of this link and the ata/raid drivers are what you need http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 10, 2007 | ASUS P5LD2-VM Motherboard
ASUS P4C800 Deluxe Motherboard Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
