Question about AOpen F70PS 17" Flat Panel LCD Monitor
A OPEN F70PS 17" flat screen monitor works on my think pad laptop great. Get no picture when hooked to e-machine T1440--has on board video Intel direct AGP 3D
  • 585 Answers
Check the resolution in the T1440. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the e-machines splash when the computer is turned on. If that does not appear, maybe another monitor will not work either, indicating another problem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 11, 2009
LaptopDell XPS,M1730 powers up but no Display on screen
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is the likely problem, or the backlight behind the display is faulty, but if both have the same symptom it is the video graphics card normally built into the motherboard.
Apr 30, 2012 | Dell Xps 17 Laptop Computer (Intel Core i7...
Picure does not fill out the screen
First try it on another video source. If it changes it's the source. If I hook a monitor to my laptop and put it display and external at the same time it uses the wide screen settings of my laptop display.If I go external only it fills it totally out. Also get into the on screen display and find where you can do reset or auto adjust. If nothing works regardless of machine it's on then the display may be failing and need service. Capacitors on the power board in LCD monitors since about 2004 have been prone to failure.
Jul 02, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Power not coming on?
Please open it up and look for bad caps with bulging tops, 90% of monitors failed due to bad caps, see example here: http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/
Jan 04, 2010 | AOpen F70PS 17" Flat Panel LCD Monitor
It sometimes takes too long to turn on, and lately it wont turn on t al. the led flashes green for 10 minutes untill it shows image and it started not turning on or showing any image
your power supply may need repair. open the back of it. look for capacitors that are leakingo or crowned. or you can take it to have a shop reepair it.
Dec 25, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Only 2/3 of screen working
sounds like the lcd monitor is going bad. To make sure though, hook up another monitor to your computer and if the monitor shows a full picture then that means the original monitor is bad.
If your replacement monitor shows a 2/3 screen, then you know its a problem with your video card.
Nov 30, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Dell monitor black screen
If you have another monitor for desktop hook other monitor up then under hardware and software in control panel, add the dell monitor, then hook it up. Some operating systems need the driver to be added first. My brother almost threw away agood dell lcd monitor before I told him this, now he loves the lcd, works great.
Mar 09, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Oct 24, 2008 | IBM ThinkVision L170 17" LCD Monitor
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
AOpen F70PS 17" Flat Panel LCD Monitor Logo
91 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
