Question about KitchenAid Pasta Roller / Cutter Set
Pasta attachment rollers leave black marks on pasta
As the pasta rolls between the rollers thin black specks appear on the pasta
2 Suggested Answers
SOURCE: we need to find a
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!4_3_2012_1_04_19_am.jpg
Posted on Apr 03, 2012
The vacuum leaves roller marks,
check the small black plastic rollers in the head are rolling freely
if not replace them
Oct 22, 2016 | Vacuums
Kitchen aid pasta roller
Hi, you may have a broken shear shaft. Here is a link to replace it.
http://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
EPSON WORKFORCE 840 AUTO FEED COPIES HAVE BLACK LINE DOWN THE SIDE
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
Just bought Imperia RM220 that won't start at all.. WHat's wrong with that?
Just attach the pasta machine to your countertop, table or cutting board with the clamp.  Put the crank in the hole.  The pasta goes inbetween the rollers of course and turn the crank.  Start with the rollers furthest apart or the biggest number and roll the dough twice on each number.  There are videos to watch on my website:
http://noodlemakermachine.com/wp-admin/post.php?post=16&action=edit
 Good luck with that!
Feb 15, 2011 | Imperia pasta machine - Original Made in...
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Are there instructions for the Norpro ravioli attachment? I have a Norpro two piece set attachment for my Norpro pasta maker. It came with no instructions whatsoever. Are there any printed instructions...
Just bought one,so you're in luck lol.
Roll pasta dough until thin and translucent.
Dust lightly with flour.
Cut dough into four rectangular strips,each about 12 inches by 4 inches.
Place on strip of dough over the frame.(the metal part)
Press dough into frame with the indented tray.(plastic piece)
Remove the indented tray.
Fill pouches as desired.
Place a second strip of dough over the strip with the filling in it and press strips together with your fingers.
With a rolling pin,roll across the dough covered frame,gently at first and then increase pressure until the zig zag edges of the frame are visible through the pasta. The ravioli is now sealed. Remove excess dough and re-roll.
Remove ravioli from frame by by tapping it on counter.
I find that these instructions aren't the best. They should tell you to lightly flour the frame before using or else it's hard to remove the ravioli. I also find that tapping it makes no difference...I always have to push them out through the bottom.
Good luck and enjoy!
Oct 05, 2009 | Norpro Ravioli Maker & Press W/ Recipes &...
I have an old vitantonio tortellini maker (model #520) but i have lost the instruction manual
1. Make your favotite pasta dough, roll out thin.
2. Place a sheet of rolled-out pasta dough on the metal plate, press down with the plastic mold to create the ravioli pockets.
3. Fill the pockets with your choice of mixture (cheeses, meats, spinach).
4. Then brush the top of the pasta sheet with egg wash or water and place a second sheet of pasta dough over the first.
5. Then use a rolling pin to press down on the assembled raviolis.
6. The pressure of the rolling pin will adhere the two sheets of pasta together and will cut the raviolis apart along the edges of the metal plate.
7. The result is a dozen perfect homemade raviolis!
Sep 27, 2009 | Kitchen Appliances - Others
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
KitchenAid Pasta Roller / Cutter Set Logo
88 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
