Question about Panasonic TH-50PX25U/P 50 in. HDTV Plasma Television
Loss of picture and sound.
I have a TH-PX25 television that I purchased in 2004. Input is an antenna. Signal strength is good (about 90). After about 1 year, the picture would become eratic on occasion, and blank out all together, including the sound, sometimes. The problem occurred more frequently over the years, and now I rarely get a picture to remain for more than a couple of hours. At one point I changed inputs from the A port to the B port and that reduced the frequency of the problem, but now both ports are bad. Meanwhile, the picture-in-a-picture works just fine.
  • 77 Answers
Did you check in your tv settings about which input is either cable or antenna, try doing a "autoscan" of channels based off your antenna, after seeing what your main input is
Posted on Jan 11, 2009
What causes a snowypicture
Low input signal strength, due to poor antenna connection; defective tuner, improper orientation of the antenna; etc; might cause a snowy picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If the transmitter is so far away, it too can be the cause, as the signal falls at the antenna to be low. If this is the case, connecting a signal booster; between the TV set and the antenna will give better result.
Jul 30, 2014 | Sceptre Televison & Video
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
    Tune to a strong channel.
    Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
    If the signal strength show good and your picture is lost then a problem may be in the tv.
    More than likely the antenna is not picking up a strong signal. Try rotating it some.
    You can go to www.tvfool.com to see what stations are in your reception area.
    Feb 13, 2011 | Televison & Video
    Which antenna can be used for sony trinitron
    Hello
    for Tvs have larger viewing areas, yagi outdoor antenna is the best. With a telescopic indorr antena, although it will work, but there will be some snow in picture, and some interferance, which will be noticable with large screens. Moreover yagi antenna is best for good signal strength and choose an antenna which ahs larger number of cross bars, as it will rise the strength of signal as well as clarity of the picture. Ok
    Dec 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    About 30 days ago I started losing the signal for CH 5 in Nashville, TN The strength is in the 80 to 90 range but the picture breaks up and the sound cuts in and out. Have new converter boxes,...
    Have a close look at the cables between the converter box and the television set. Perhaps one is damaged by a tight bend or has a damaged connector.
    Nov 02, 2009 | Emerson Televison & Video
    Loss of Digital Shows??
    U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
    Oct 26, 2009 | iLO V27DMBX Television
    HD50LPW42 screen is black with antenna inputs
    It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
    I hope that this helps you solve your issue.
    Thanks
    asnowman
    Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
    RCS Scenium
    What is your TV input connection? Are you using Antenna? Cable? Dish?
    The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
    If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
    Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Hdtv has no sound when watching hdtv channels using a rabbit antenna. good picture quallity but no sound
    newer television sets employing hd or digital require good antenna signal strength to allow the sound to come on.
    there is an auto muting device built into the set so as if the picture is at all snowy it will mute the sound.
    what you can do however with this set is to enter service mode and there is an option that you can change that will disable this muting aspect of the television.
    The reason why a lot of sets have this option is to prevent damage to speakers.
    Jul 11, 2008 | Televison & Video
    Panasonic TH-50PX25U/P 50 in. HDTV Plasma Television Logo
    114 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
