Question about Toshiba 27DF46 27" TV
Picture limited to a single pixel horizontal line, sound fine
I recently purchased a floor model (Toshiba 27DF46) at an electronics retailer. it worked fine for about 3 weeks, then started randomly losing picture to a single pixel-wide horizontal strip across the screen for a second or two then return back to normal. over the next month it was happening more and more, and now, no picture shows up, just the line of light...almost seems like the whole picture has been squashed into that one line. again the sound still functions normally. Any thoughts? thanks!
  • 6 more comments
  • Anonymous Jan 24, 2008
    I've had my Toshiba 27df46 for 18 months. One year ago it broke and the repair person "repaired a defective solder connection at q803 on the circuit board". This was covered under the warranty. Now I have the same problem discussed above -- a single pixel horizontal line and occasional sound problems, but I am out of warranty. My question is "are these two problems related?" Is this something that the repair person should have caught when fixing the solder at Q803? Or is it Toshiba's fault for making a defective TV? Or am I just plain unlucky?
  • NickMantia Feb 06, 2008
    Does anyone know how to force this to happen? I'm having the same problem with my Toshiba 27DF46 27" Flat CRT TV. I have an extended warranty through Best Buy, but they will not come out unless the TV is showing the problem. Mine seems to happen randomly when watching TV, watching DVD, but I have not been able to figure out how to replicate the issue
    Any help is much appreciated!
    Nick
  • RANGERGHS Apr 25, 2008
    SAME PROBLEM.....AS TIME GOES ON IT GETS WORSE. IONLY THAT HAS BEEN TRIED IS TO SHUT IT OFF AND TURN IT BACK ON AGAIN. iS THERE ANYWAY TO FIX IT WITHOUT OBTAINING AN OUTSIDE SERVICE?
  • Anonymous Jun 28, 2008
    did you find a solutIon?
  • gwwis48 Sep 06, 2008
    hi. i have a 27df-46 also. after the first week i have nothing but a thin line across the middle of the screen. please help. thanks
  • Ovets Jan 07, 2009
    I have the same problem (intermittent collapse to horizontal line). I tried resoldering the yoke connection to the main board and tightening the yoke connector but no improvement. I suspect its the vertical amplifier.
  • prschu Mar 25, 2009
    I have the same issue with my 27DF46. I read the above and decided to follow the suggested inspection. I did not find any cracking in the soldering, but found that, as long as I had the back of the TV off, it worked fine, but when I put it back together, it would flat-line again after a few minutes to a half hour. Over time I realized that, when the room was colder, it would not occur, but when the room warmed up, the TV would flat-line again. It occurred to me that the heat sink was likely not doing its job. I tried placing a small fan next to the TV & as long as the fan is on, there is no problem. So, I wonder if there's a way to improve the heat sink function? PS - There was (heat sink) grease between the IC and heat sink, but no screw to connect the IC to the heat sink. I tried installing a screw, but that didn't help at all.
  • prschu May 11, 2010
    Bill,
    at all. Any other suggestions?
  • 934 Answers
This is actuall quite a simple problem... What you have explained here is a loss of vertical deflection. By the symptoms you described, working now and not working it's most likely the the vertical IC an LA7847-E has probably become ring-cracked at the point where the pins are soldered to the pc board. Depending on how long it has been allowed to arc the IC may have failed also, but they are not terribly expensive or difficult to repair - at least not here in the shop. The main board has to be removed. Locate the vertical IC - it will be mounted to a metal heat sink and the IC will be stamped LA7847. Then turn the board over and inspect where the pins are soldered to the foil side of the board. One or more will look ring cracked or fractured all the way around the pin. At this point you have two options, carefully reflow solder over each pin and put it back together or replace the IC by de-soldering it and removing it from it's heatsink. remember to use a good heat sink grease when applying the new IC.. There should also be a couple of caps in pretty close proximity to that IC... One should be about 50v/100uf and in the shop here we test em all... You might also just replace that one for good measure - they're not expensive either... If any of this sounds too complicated take it to a reputable shop and pick it up in a day or two.. Job shouldn't be that expensive or time consuming. My record in the shop here for doing those is 15 in one day. Average cost for that set, we charge is under $100 if you bring it in and pick it up.. Hope this helps Bill If you're calling around to the repair shops you might just ask if they have that IC on-hand or if they will need to order it..
Posted on Jun 07, 2007
I had the same problem and resoldered the connections to the vertical amplifier, but it did not fix the problem. Then I looked at the thermal connection of the amplifier to the heat sink and noticed that the thermal grease only covered part of the area between the amp and the heat sink. I unscrewed the amp from the heat sink, removed the thermal grease, and then screwed the amplifier back on to the heat sink (with no grease). Now everything works fine. I will add thermal grease when I get a chance. I think that the problem was caused by a mis-application of the grease at the factory. It looks like the grease was there, but not in the right position to be effective.
Posted on Apr 10, 2009
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
I Have a Toshiba 27DF46 The Picture is shifted to the right about 3 inches or so. other than that the picture is fine but I can't see the right edge on the picture. Any thoughts
Try going into the picture settings in the options. Many Toshiba TVs have the option to move the picture up, down, left, and right. See if you are able to position the TV to the left more.
Also, see if there is a reset button in the options. A setting may have been switched that caused this.
Mar 02, 2011 | Toshiba 27DF46 27" TV
Hello, I purchased my Toshiba TV 27DF46 at a thrift store and it did not have a remote and I cannot figure out how to get my av ports to work. I have tried changing the channel manually and using my...
There are several different options to solve your problem. You should be able to program your cable box remote to replace many (but probably not all) of the functions of the Toshiba TV remote that you're missing. Read the user manual that came with your cable box remote to find out how to program it to control different types of components. It's not very difficult and that would be your least expensive option. Another suggestion is to buy a "universal replacement remote" that are sold in many electronics stores. Once you program those universal remotes, they will perform most/many of the functions of the original (Toshiba) manufacturer's remote. A "universal replacement remote" can cost anywhere from $20 to well over $100 depending on how many electronic components you want to control. My best suggestion would be to buy a replacement remote that was specifically made for your Toshiba model 27DF46 TV. There are many companies on the Internet which sell those remotes specifically made for your TV. The cost is usually between $25 - $35. One last inexpensive option would be if you already have any other Toshiba components (like a Toshiba DVD player), in many cases, the remotes are nearly identical and will provide most or all of the same functions. I would start by trying whichever option makes the most sense for your particular situation. Good luck.
Aug 11, 2010 | Toshiba 27DF46 27" TV
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
Mar 13, 2010 | Toshiba 32D46 32" TV
Sony Cybershot DSC-S500 bad photo resolution problem
Electronic shutter in lens mechanism got bad and you need to replace complete lens assembly of DSC-S500 camera.
Of course new lens assembly would cost more then camera worth so best option is to buy new camera.
Jul 23, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Thin horizontal line with a Toshiba CF3062A
This is a problem with the vertical circuit that is usually a defective vertical IC. This part costs $10-$20 and is easily replaced. Sometimes there are capacitors in the same circuit that need to be replaced as well. Dan
Jun 09, 2009 | Toshiba Televison & Video
36 Inch Toshiba - Single Bright Horizontal Line
You're losing your horizontal voltage that drives the fly back transformer. Poking around inside can be hazardous to your health since you have to worry about high voltages present on the picture tube even when the TV is off. You may still be able to get parts for those old TV's but they may hard to find. You can try here, but if you have no background in TV repair, it will be pointless.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Mar 20, 2017 | Toshiba CZ36T31 36" TV
Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
Sep 15, 2007 | Televison & Video
Toshiba 27DF46 27" TV Logo
785 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
