Question about Frigidaire 14 Cycle Tumble Action Washer
FRIGIDAIRE GALLERY SERIES WASHER FLASHING E50 CODE
the dr
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
  • 10 Answers
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
SOURCE: frigidaire gallery series washer and dryer....has been lying on it's side in storage for approximately 8 months. When we finally put it in place there was a pool of yellow colored oil in the washing m
That oil is transmission oil. Not to worry there will be lots left inside
Posted on Jul 13, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
Macmarkus
  • 2605 Answers
SOURCE: can you replace just the rear bearing on a
Hi, Welcome to FixYa. I theory...yes it can be done. The problem lyes in 1) finding just the bearing & seal... and 2) the shaft of the inner stainless steel basket is likely going to be badly worn or "scored" as a result of the bearing failing. I always replace the entire assembly, but if the bearing and seal where available seperately it would still require the inner basket and a complete tear-down and just as much labour ( or more likely ) it is less expensive to do the complete assembly. I'll leave that with you, let me know if I can assist you further. Macmarkus :)
Posted on Aug 30, 2010
How to fix gallery frigidaire code pau
Hey friend, thank you for the post!
I see from your post that your Frigidaire washer is displaying a PAU code. Normally means the washer has been paused, which could be cleared be pressing either the cancel button or start button once. If that does not clear the code you could try resetting the appliance by disconnecting power. This could be done one of two ways by either unplugging the washer or flipping the household circuit breaker for ten minutes. Please comment back I would like to know if this information has been helpful. -Matt
Jul 23, 2014 | Frigidaire Washing Machines
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
you locked the door, down the lock keys to unlock
May 23, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire 14 Cycle Tumble Action Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
