Question about Onkyo TX-DS656 Receiver
I want to run remote speakers from this unit to my bathroom.
I see where there are remote speaker connections in the rear of the unit. I have connected the speakers, then I tried to press the remote button on the front and the remote control. However, nothing came out of the speakers. What should I have done or yet still do?
  • 14 Answers
You need to hit the multi-source button, then the soucre (fm/video.dvd etc) and then turn on the remote speakers
Posted on Jan 24, 2010
  • 336 Answers
You may need to turn off the surround sound. Your receiver probably uses the same amps for remote speaker as it does for the surround speakers.
John W
Posted on Jan 11, 2009
Why is there no sound from rear speakers?
One of the buttons you pressed probably disabled surround sound
Nov 03, 2015 | Denon AVR-791 7.1 CH A/V Home Theater...
My Sony home theater video center speaker don't work.
Check the connections between the speaker input on the rear of the unit, and the cable to the speaker itself, ensuring there are no weak spots or cracks. Check to make sure the centre speaker is securely connected to the correct port/socket on the rear of the unit. Also check settings of the surround in the unit's setup option - and if the display shows speaker icons and the centre one is not illuminated, it is probably OFF, or the selected mode/function does not require that speaker. If this is the case, change the function using the unit's function (mode) button, either on the front, or via the remote. (some home theatre systems have multiple modes/functions, for example MOVIE, DYNAMIC, DTS, 2 CH stereo, etc.)
It is also a good idea to do a 5.1 surround test - some DVDs have this as a bonus setup feature, but you can do this with a normal audio source, such as from a DVD or a TV program. You should hear a sound from each of the speakers, and if the unit has a volume control or each speaker does, make sure these are set to a relatively equal audible level.
If after trying the above, you still get no sound from the centre speaker, it is possible either the speaker itself or the unit has a fault. If it is the former, consider replacing the speaker. If it is the latter, this could be expensive in terms of parts and labour - as service technicians charge an arm and a leg for repairs to the amplifier circuit in these units.
In any event, try the basic, simple steps above before considering any further action. It could just be a faulty speaker, a bad connection, an incorrect connection, or a mode/function setting is wrong, causing the speaker to be OFF.
Jun 28, 2011 | Televison & Video
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Jul 11, 2008 | JVC KD-G110 CD Player
Where do i connect my amp to my paosonic cq-dfx301u
On the the back of the unit there will be be a set of rca leads marked pre out run set of rca leads from these to the input connectors on your amp,you will also need to run a single wire from the wiring harness of head unit look for a wire marked remote (usually blue)run this to the terminal on amp marked remote ,you will also need a fused power cable run to battery +and a earth cable - screw this to metal part of chassis ,then run your speaker wires make sure + - symbols on speakers get connected to + - terminals for speakers on amp.
Apr 20, 2008 | Car Audio & Video
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Nov 06, 2007 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
Onkyo TX-DS656 Receiver Logo
484 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
