Question about Craftsman Tools & Hardware - Others
Craftsman rotary tool bench 706.655110 - Craftsman Tools & Hardware - Others
rowdy45176
  • 2176 Answers
SOURCE: Where can I get a PDF copy of the owners manual
go to Managemyhome.com and under manual type in your model number and after the 4 add a 0. The manual is 37 pages long. If I have helped you with your request would you please rate this reply accordingly and Thank you.
Posted on Oct 03, 2009
Testimonial: "Thank you very much. This Manual was difficult to find and you helped get it. Much apprciated."
  • 28 Answers
SOURCE: coupler between motor and chuck disintegrated,
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
$2.57 In stock
Posted on May 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: have a MODEL 572.610530 CRAFTSMAN
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
Posted on May 18, 2011
rowdy45176
  • 2176 Answers
SOURCE: my craftsman rotary tool burnt
usually but take a look at the field for discoloration of the windings, if you have a volt ohms meter take a reading across the field leads and reverse the contacts and the readings should be about the same, if there is a major difference the field is probably bad also.
Posted on Aug 31, 2011
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
I was using my friends Craftsman Rotary tool to shave down a metal door jamb and it got hot so i shut it off. Turned it back on for a second, and has not worked since. It's been 3 days. Is there a way...
You probably burned up the brushes.You can take it to Sears and have them send it in to have them replaced, but in the long run it will be cheaper and a lot faster to buy a new one. Rotary tools are not made to take a lot of stress. Besides your friend will see how much of a nice guy you are and how honest you are and won't be afraid to lend you tools in the future.
Jun 12, 2011 | Craftsman Tools & Hardware - Others
My craftman single sped rotart tool the chuck with
Do you have any kind of a clutch on this drive ? I may be in bewteen settings.
Please let me know
Feb 06, 2010 | Craftsman Single Speed Rotary Tool
Where can I get a PDF copy of the owners manual for the Craftsman All in One Cutting Tool Model # 183.17254? (AC Rotary Trim-Cutter)
Sep 30, 2009 | Craftsman Tools & Hardware - Others
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
As of 5-18-2010
Flex coupling
Weight: 0.18
$2.57 In stock
Sep 09, 2009 | Craftsman Single Speed Rotary Tool
Tools & Hardware - Others Logo
357 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
