Question about Samsung HCN436W 43" Rear Projection Television
My tv is actuall a SP43W6HPX/XEU
Hii have been havin a real problem with my rear projection tv i some how got into some secret part of the tv and now all the colour and focus is completly out, is there a setting that i can do to put it back to normal? thank you very much.
  • dkb23d Oct 12, 2008
    HOW DO I GET INTO TH SERVICE MENU.
    IVE TRIED THE MUTE 182. BUT NOTHING COMES UP. AM I DOING SOMETHING WRONG.
    THANKS
  • 934 Answers
By getting into a "secret place" I'm assuming you mean the service menu and changed some numbers and settings, right? If so, there is no magic escape key on TV's unfortunately. The geometry and settings you changed will be challenging to say the least, even for a skilled technician. I learned many years ago to write down the values in the service menu before attempting any modifications - so it could be put back in the event that the changes made it worse... What I would suggest is calling a tech for an in-home visit. Explain that you inadvertently may have changed some settings in the service menu and need it adjusted. It will probably cost a one-hour service call, here we charge $60 an hour and if within the hour the tech can't get it back at least you'll know that you may have other underlying problems. However, if this is indeed what you've done a good tech should be able to re-adjust most of the parameters in the service menu in a one-hour service call.. Hope this helps. Bill
Posted on Jun 07, 2007
I have a samsung sp43w6hpx which started to mix colours and now it just goes to standby can anybody help please as its a good tv and i`d like it fixed
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Samsung HCN436W 43" Rear Projection...
Having trouble with samsung projection tv / sp43w6hpx/xeu. done manual convergence and got the picture and colour nearly right but across the top half the tv the picture is bend upward/ what kinda part...
Look for 2 big black ICs they will have the Part number on them,example STK392-110
Mats Electronics has them replace Both ICs. 1-800-628-1118 also in front of ICs is 2 resistors low ohm 2.7 or 3.9 replace them.
Mar 01, 2011 | Samsung Televison & Video
SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Dec 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung sp43w6hpx/xeu
Convergence is out. Go to service menu and set it.
Dec 23, 2007 | Samsung HCN436W 43" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Yes you must go to menu and set the convergenge. It is easy. If it doesnt tune in or set to be ok you must get somebody to set convertions manualy thru service menu.
Hope it help
Aug 10, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
Jun 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN436W 43" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
