Question about Garden
What should the compression be on a 7.25 hp briggs and straton motor
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
  • 202 Answers
SOURCE: gas in oil 12.5 hp briggs and straton
the float in the carb is stuck open, its flooding with gas. the gasoline is going past the rings and/or valves into the crankcase. you need to remove the float bowl and unstick and reset the float to specs, maybe a new seat and needle and change the oil before restarting.
Posted on Jul 26, 2009
mickey813
  • 472 Answers
SOURCE: picture of governor linkage on briggs+straton
try this link all ya got to do is put in the modle #
Posted on Oct 01, 2009
mowerman1857
  • 389 Answers
SOURCE: what is the oil capacity of the briggs ans straton
Approximately 40 ounces. Put in a full quart first, then add about 1/4 of the second quart and start checking the dipstick until you are at the full mark. Each time you add more, let it run down into the engine for a minute or so before checking or you will get a false reading. If your engine has an oil filter and you changed it, figure about 2 extra ounces for the filter
Posted on Oct 10, 2009
  • 110 Answers
SOURCE: lawnmower with 5 hp briggs ad straton
It sounds like the choke is comming on or you are prinming it again? Dont prime a warm engine
Posted on Nov 17, 2009
I have a briggs &straton intek 26 hp and the compresion seems to be not releasing.what can i do?
If the valves are adjusted too loose, the compression release will not work, and will make starting the engine difficult. I believe the clearance is supposed to be .005". If the clearance is too large, the 'bump' on the cam will not move the valve off its seat when cranked slowly, and compression will make the engine hard to crank over.
Jun 18, 2012 | Measuring Tools & Sensors
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Starter motor can't turn engine through compression stroke
valves are out of adjustment. reset them and it will do fine.
Apr 07, 2017 | Yard Machines Garden
What should the compression be on 5.5 hp
Briggs and Straton recommends spinning the crankshaft by the flywheel opposite from the normal direction (which is clockwise) with the normal spark plug installed. A sharp rebound (as it compresses the trapped air since the compression release mechanism is not active in reverse) indicates good compression. The same method is sure to apply to a PSI test, its just a matter of finding a way to crank the engine backwards.
Jun 16, 2010 | Mtd Garden
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jul 15, 2009 | Mtd Garden
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
