Question about Panasonic NE1054F - Pro Microwave Oven, 10 Keypad, 6 Power Levels, 100
Lead pops off thermal fuse on my panasonic ne1054f
My microwave would start and then shut off. I tried this a couple of times and then it just stopped all together. When I took the cover off I noticed that one of the lead wires that connects to the thermal fuse (?) that's screwed on top of the magnatron was not connected. It was blackened and looked like it had sparked. I tested the fuse and it tested fine. I tried to solder the metal plate back onto the fuse - once I had it secured, I retested the fuse, it was still fine. I hooked up the wires....turned on the unit for 10 seconds and it seemed fine. No sparks, etc. I tried it again for 20 seconds and while it was running, it melted the solder loose and the plate popped off. What would cause this? Thanks in advance for any assistance you can give!
  • Panasonic Master
  • 9,047 Answers
The thermostat and the terminal on the wire must be replaced.
When a terminal is overheated (usually due to excessive current or heat due to a loose connection) the physical characteristics of the metal change, and they will never be the same.
You should also cut back the lead wire an inch or so until you get a bright shiny copper color, making sure you have cut away all the dull pinkish wire.
A similar service manual can be found here, and it should be close enough to help you.
You can order Panasonic parts from Encompass here.
Posted on Dec 01, 2012
Testimonial: "Thanks for the help! It is much appreciated! "
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: White Panasonic
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Nov 18, 2007
  • 234 Answers
SOURCE: Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Posted on Mar 14, 2009
caroldon
  • 17129 Answers
SOURCE: Hi, I have a 1200W 44 litre Panasonic Microwave
It seems to me that the magnetron has burnt and failed. So if there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. If there is soft spots on the magnetron and visible damage seen on the magnetron then it has failed. Finally after drying and a full clean up ,
keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron is faulty. replace with same type.
Posted on Apr 11, 2011
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
Feb 09, 2017 | Panasonic Microwave Ovens
Panasonic microwave NN-T543W
The thermal fuse that protects the magnetron is defective or the magnetron is getting to hot causing it to shut down, if the fan is not running cools the magnetron it will shut off.
Mar 15, 2012 | Panasonic NNSD967S Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
My Panasonic Microwave NN-T573SBBPQ cuts out after 3 seconds. what can I do? Or am I better of replacing it?
This sounds like a magnetron problem, if it gets to hot, there is a special thermal fuse that will open up if it senses abnormal temperature rise from the magnetron and after a cool down period it will reset itself. In rare cases I have known the thermal fuse to become defective and cut out prematurely. My feeling is replace the oven! because by the time you get a appliance repairman in for a sevice call and parts you probably could have bought a new microwave oven.
Jan 19, 2011 | Panasonic NN-T990SA Microwave Oven
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
Microwave shuts off after 10 to 15 secs and does not heat up. Would the inverter or magnatron be faulty?
The following List of things would cause that, you can test each one till you find it or drop it at a service center...
-oven fuse
-thermal cutout
-door interlock switch or monitor switch
-thermal cutout
-fan jammed or faulty
-diode
-circuit board, triac or magnetron
let me lnow if you want any further instructions...
~chuck : testamonials appreciated!!!
Oct 31, 2009 | Panasonic NNT995SF Stainless steel 1250...
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
Where is the fuse and reset button for the Panasonic NE1064TC located. Can anyone help with this. Thanks,
On our Panasonic microwave there are two fuses, a regular cylindrical current fuse and a one-time "thermal fuse." If you remove the case which in our unit is held on by a handful of screws on the back of the unit, both fuses are visible if you stand at the rear of the unit and look on the left hand side. The thermal fuse is the gadget attached to the top of the magnetron heat sink. It is typically in the white wire. The current fuse is located in the black wire. I hope this helps!
Mar 27, 2009 | Panasonic NE-1054 1000 Watts Microwave...
Panasonic NE1054F - Pro Microwave Oven, 10 Keypad, 6 Power Levels, 100 Logo
60 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
