Question about Elite Sl 3000 Ul Sliding Gate Operator
Where is the smart button on my robo swing r900
Trying to program liftmaster remote to my gate but can't find smart button.
2 Suggested Answers
  • 14 Answers
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Posted on Mar 13, 2010
I lost my remote for my Viking R-6 gate opener. the store sold me a liftmaster 890Max remote for it but how do I program it. I can not find the learn button on the viking R-6 gate opener????
The Liftmaster remote you purchased should have come with instructions for programming unless it is preprogrammed to work with your Viking gate opener. You may have to return to the point of purchase for clarification.
Oct 19, 2014 | Building Materials
Can the code bechanged on a Liftmaster Formula1 opener, just divorced and husband isn't nice
I have to assume a couple things here. First - I assume he still has a remote. Second - You want to change the opener so that his remote will not work and not just the keypad outside the garage. So.
To change the opener so that none of the existing remotes and the keypad will work just locate the smart/learn button on the rear of the motor unit near where all those white wires go. You may have to remove a light lens to get to it. Press and hold this button for 6 seconds. That erases the memory. Now you need to program your remotes. Hold the button down on the remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Now the keypad. Press and immediately release the smart/learn button. Walk over to the keypad and key in any 4 digit code you want and press enter.
That's it.
May 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the...
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
May 14, 2011 | liftmaster Chamberlain Garage Door Opener...
I have an elite robo swing r900 gate opener. gate door's are not closing, battery keeps beeping and it shows low battery
Nov 09, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
I NEED TO PROGRAM MY LIFTMASTER GARAGE DOOR OPENERS TO WORK WITH MY LIFTMASTER 1045-6 OPENER
If you have the correct remotes for your opener you can program them like this:
Locate the smart/learn button on the back of the motor unit. Press and hold the button on your remote while you press and immediately release the smart/learn button. Do this for each remote.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Professional and Clicker Programming Problems
The Security+ system is a rolling code system and is digital, so it will work with the Homelink in vehicles and with the remote control units that come with the opener. Also with new remotes that are purchased specifically for that opener. Your "clickers" require specific instructions and you need to use the Smart Learn function in order to use them with this opener. In addition, check the Brand Switch settings to be sure they apply to your opener, and the correct Smart Button color on the opener. Read carefully to determine whether you need to set ANY dip switches at all or can you just set them all to off depending on your opener? Check the instructions carefully. Here's a link to the page where you can download a copy of the Clicker instructions if you don't already have it:
. Clicker Model CLT1D Remote Control Owner Manual
May 14, 2009 | liftmaster Chamberlain Garage Door Opener...
Unable to program my new 2009 Altima Hybrid Homelink to my gate
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
Apr 05, 2009 | 2008 Nissan Altima Hybrid
Elite Sl 3000 Ul Sliding Gate Operator Logo
51 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
