Maytag se1000 has no power to the touch pad. the control board has power, both have been replaced but no help. What are we missing?
Repair tech has worked on this and call Maytag no light as to the problem.
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 1073 Answers
SOURCE: I have a Maytag dishwasher
you have to power the unit back up and then holld the lock in for three seconds, if ths does not reset it then the console not the control bord needs to be replaced it comes with a new touch pad
Posted on Apr 10, 2008
bobjrdns
  • 84 Answers
SOURCE: How to replace control board?
Maytag MFD2560HES http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1455147&PPStack=1
Posted on Oct 22, 2008
  • 163 Answers
SOURCE: Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Posted on Mar 12, 2009
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Oven Fault Codes
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F1 error code and beeping on a ge doubleoven
Hello there:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
F1 appeared on the panel screen,my model is MGR5770ADB.Please reply.
HI. Essentially, this will be the result of a failed touch pad. Some models incorporate the touch pad in to the ERC(control board) as a single assembly, in which case, the test I will post below is not necessary. If your touch pad is Incorporated in to the control board assembly, Simply replace the entire Control board. Follow the test below if the touch pad is separate from the control board.
Warning: If you feel in any way uncomfortable with performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 21, 2009 | Maytag MGR5770 Gas Kitchen Range
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag oven reads fi
Defective touch pad or clock (ERC)
Jun 01, 2009 | Maytag Ovens
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
