Question about Spectroniq PD-1100 DVD Player
Need help installing cables from dvd to tv
Can anyone help
  • Anonymous Jan 26, 2009
    connected as per manual-won't switch from tv reception to dvd .does satalite box have anything to do with my problem
  • 55 Answers
What connection are you using?
If you're using RCA cables, the most common. They are color coded, as will your tv and dvd player be. Just connect the output on the DVD player to an Input on your TV. Change your TV to that input and your good to go.
Posted on Jan 11, 2009
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
Same crazy problem here! I have a converter box and can't figure out how to get the dvd to work. I managed to get a b/w picture to come barely come in (has rolling horizontal lines). What channel is it...
The converter box simply installs between your Antenna and your TV (tune to channel 3 or 4) http://digitaltips.org/docs/FlosTips.pdf
A dvd that does not Record is designed to simple install into a separate Input connection on the TV (do you have a VCR/DVD combo?)
Do you have an older TV with only one "Input" for a cable connection? (no Red/Yellow/White Inputs) if yes you may need to take a trip to Radio Shack
Mar 12, 2010 | Zenith Z25X22S 25" TV
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Unable to install correctly - hd tv ok - dvd wont install
what type of cables are you using? are you using the HDMI cable that comes with the unit? your tv also has to be HD compatitable.
Dec 19, 2008 | Philips DVDR520H DVD Player/HDD
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Spectroniq PD-1100 DVD Player Logo
63 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
