Question about Alpine MRP-M500 Car Audio Amplifier
Alpine MRP-M500 i recently purchased the alpine mrp-m500. hooked it up, worked fine for 20 minutes and then cut off. no fuses blown, evrything is hooked up right. i have it hooked up to a 12 type r dual voice coil. whats the prob?
  • John Larsen May 11, 2010
    what size are your power and ground wires??
  • TDWPgtp May 11, 2010
    is it a dual 2 or dual 4 ohm voice coil sub? have u tried replacing the fuse on the power wire, as sometimes the soldering melts, but the fuse does not appear to be bad. does it light up all?
    Scholar:
  • 124 Answers
You need to check the Fuse on the Power Wire and check the ground wire to see if has loosened up. Also check Power Wire as well.
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Posted on Jan 30, 2009
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
How to install
Here is a copy of the owners manual that guides you on how to install, including the wiring......hope this helps
http://support.alpine-usa.com/products/documents/OM_MRP-M500.PDF
Sep 19, 2010 | Alpine MRP-M500 Car Audio Amplifier
I have an Alpine MrP-M500 that is not giving off sound. The light is diming, and blinking meaning it is in "safemode." ive done everything, new fuses, ground is good, wires are good, sub is good. I got it...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Alpine MRP-M500 Car Audio Amplifier
Is a mrp-m500 1 ohm stable
Hello vincent_i_fa,
No, the Alpine MRP-M500 is only stable down to 2 ohms.
Hope this helps.
Sep 11, 2009 | Car Audio & Video
Amp light on , but subwoofers stop working after 5 seconds
check sloder conection in amp. if your amp is in trunk it copuld have over heayed and mealted the metal.
Jul 12, 2009 | Alpine MRP-M500 Car Audio Amplifier
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
I hook up my alpine amplifire and the red light for the fuse protection comes. on what could it be?
It is either hooked up wrong or the wire you are using is too thin. Be sure to use the proper gage wire for the output of the amp.
Mar 26, 2009 | Alpine MRP-M500 Car Audio Amplifier
Alpine MRP-M500 Car Audio Amplifier Logo
720 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
