Question about Zenith VRB410 VHS VCR
My vcr will not record a program when the time set is used, only when I press 'record'
When I set the vcr to record, I only get snow when the show is played back. It works when I record it manually, and will play any tape perfectly. this is my only problem
2 Suggested Answers
rapanSF
  • 150 Answers
SOURCE: When playing back a recorded program only get sound. No picture
Either the program is copy protected or connection to TV is mismatched.
Posted on Mar 25, 2009
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I would like to tape my programs on the vcr(goldstar) I am not used to this product
do you wish to record while watching or while away.....while watching make sure your vcr is set to CH 3...when the show comes on press record
(a blank tape should be inserted) the red button on most vcrs.......while away the channel selector must be on the ch you wish to record...using the remote for the vcr press menu/program a event (this is where your vcr most have the correct date / time and not flashing 12:00)..set the day..time to start recording and time to stop recording..your ch will always be 3..now that vcr is set the main thing is make sure that cable channel selector is on that channel
happy recording
Aug 08, 2010 | Televison & Video
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Timer programming
The remote control is key to timer recording. Notice the selections are color-coded: grey-black for VCR, gold for DVD. Then look at the second and third rows of buttons. Each button has multiple functions depending on if the VCR or DVD button has been pressed. To record from TV signal to VHS, press the VCR very top button. (The controller will also control your TV if set up properly, so be sure the small switch at the top-left of the controller is set to the VCR/DVD side. I use a separate controller for my TV so I never change this.) Now press the "PROG." button located beside the "3" button. (Your television must be on and set to "see" the VCR not the normal TV signal.) Now look at the second row of buttons, the ones with the "+" signs. The grey words below them indicate what they'll do when pressed (the same buttons do what the gold words say when the DVD is selected.) So to set the start time, press the first "+" button with the word "START" below it. That sets the start time of the show you want to record. It'll go in 30-minute intervals if you hold it down, otherwise it's a minute-at-a-press. If you go too far, you can back up with the third row's "-" button. When you have the start time set, move on to the next button labeled "STOP" and similarly set the end-time of the program. Continue with the third "+" button to set the date you want to record. Lastly, set the channel by pressing the fourth "+" button labeled "CH." It's a bit tedious if you have a high channel number to get to. When you have all these set properly, it's important to then press the "TIMER" button (located next to the keypad number 6). That turns the VCR off but "watching" for the settings you've just made, and it'll wake up and do the recording at the proper moment. You can confirm you've got it waiting by looking at the display on the VCR; to the left of the channel number a red "clock" image should be lit. That says it's waiting. You can program several shows to record by repeating these steps, or you can do them all sequentially by setting the first one, then pressing the "PROG" button again (rather than the "TIMER" button) and setting up the next recording. When you're done, THEN press the "TIMER" button and the VCR will go to sleep until it's assigned wake-up time.
Sep 16, 2008 | JVC HR-XVC30U DVD Player/VCR
Problem with programmed recordings
DID you set the channel on the VCR to the sttating your recording? Also does your cable go to the tv, then to the vcr? If so the channel you record will be the one your watching. Or did you accidently screw the cable into the "cable out" on the dvr?
Nov 27, 2007 | Rio DVR4100 DVD Player/VCR
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Zenith VRB410 VHS VCR Logo
15 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
