Question about Philips 32PF7320A 32 in. LCD Television
Philips 32 inch lcd remote will not work
CF is showing on top of screen which is blank and remote will not workjude
The TV is in some kind of factory modus, you have to simultaniously hold the VOLUME down (-) and PROGRAM down (-) buttons on side of the TV for 3 seconds.
Posted on Apr 27, 2009
  http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=32PFL3403/12&scy=IE&slg=en#
Posted on Jan 28, 2009
CF letters on screen
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Sep 26, 2012 | Philips 32PFL3403 32-inch High Definition...
Tip
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live...
DSLR Camera or All kinds of Expensive camera needed a good care.Otherwise it will effect by Fungus or Moisture cause the damage to your Camera.I Have a Tip to give you to Protect your Camera in inexpensive way.
Tip:Take a Cardboard Box ,cover your camera and lens with dry cotton cloth and put it inside the Box.Make a Coin size hole in any side of the box and connect a zero watts Bulb or Frigde lamp fix to the hole.(You should need only a Zero watts Bulb or Fridge Lamp)You can switch on the Lamp now.Another way is to buy silica and put it in your bag even if you travelling.Silica will obserb moisture and kep your camera dry.
on Oct 02, 2010 | Nikon D300s Body only Digital Camera
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Lcd screen is on, but screen stays black? what can that be?
Make sure the tv is on the correct input (Input 1 may be dvd player, but if you have it set to a blank input nothing will show up)
Does the TV's menu work?
Feb 28, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
Harmony remote blank screen
HI! Here's what to do if your Logitech Harmony remote's LCD screen has gone blank.
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
If the screen is still blank after you complete these steps, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty.
Mar 05, 2010 | Logitech Harmony 966208 Remote Control
LDC PHILIPS 32 SERIE 3000/32PFL340 in On the screen apears CF and the remote doesent work. can u help me please?
Pritisnes zvuk+ zvuk- i menu u isto vreme together
Push together sound+sound- and menu at same time
Dec 10, 2009 | Philips Televison & Video
32 PFL3403 IRE -code on tv cF, no sound on tv unable to use remot
i really dont know what dave1645 is on about.
all i did was press the volume and program button on the side of the tv for 3 second and it came stright back on.
no need at all for a tech to come to your house for 3 seconds work where you,ll have to pay him.
just press the volume and program button for 3 seconds on the side of the tv.
Dec 07, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 32PF7320A 32 in. LCD Television Logo
1,067 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
