Toshiba CF3062A Have a model Toshiba CF3062A that has a vertical problem no vert ical from the bottom not up to middle of the screen have replaced most of the parts in the vertical circut and ideas Thanks Very similar problem; but raster fills as set warms up, although lower 50% is distorted
  • smandry Jan 11, 2009
    It is a chassis 9150. Last night I decided to look into the problem further, after finding one of the power transistors loose on the board. After removing the board so I could resolder the leads, I saw a faint oil film under C305, C342 and CD06. A previous post from someone back in 2006 recommended replacing C305, so this was perfect correlation to what I was seeing. Resoldered transistor (sorry, can't remember which one, and I have it all back together now, but it was close to C305), replaced those 3 caps, and it works like a charm! You guys are great, thanks.
  • jpactech May 11, 2010
    whatis the chassis#? on the set is it TAC.....what is it there?
    Problem Solver:
  • 9 Answers
Check capacitors location# C305-values 2.2mfd@50v,C342,2.2mfd@50v....
Posted on Jan 11, 2009
I have a CF3062A. Picture has collapsed into a
In the old days that means your "flyback transformer"needs to be replaced.
Take it to a TV tech or junk it and buy a new one. That might be cheaper.
Jul 19, 2010 | Toshiba Televison & Video
I have a 36 inch toshiba tv model # 36A50 and i have black bar at the top and one at the bottom i only have approximently 3 or 4 inches of screen in the middle to watch. what would it be? that problem...
For one thing you have a vertical problem and since it got that way gradually you can bet that there is a bad capacitor in the vert. circuit(pump-up cap) as far as the price goes it depends on your local servicemen, i`m in canada and that sort of problem fixed at home would run around a 100.00$. good luck
Nov 02, 2009 | Toshiba 36A40 36" TV
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
The picture is only about three inches high in the middle part of screen and has a slight curve
vertical circuts or vert drive circut shady easy fix need more info on tv dlp proj plasma usually bad ic 1 or 2 18.00$apiec ver def ic look up ur part #go 2 nte electrnics.com buy part tip replace surrounding capacitors and output resistors good luck
Aug 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Thin horizontal line with a Toshiba CF3062A
This is a problem with the vertical circuit that is usually a defective vertical IC. This part costs $10-$20 and is easily replaced. Sometimes there are capacitors in the same circuit that need to be replaced as well. Dan
Jun 09, 2009 | Toshiba Televison & Video
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Toshiba Problem
Look, replace all capacitors around horizontal transistor, if dont work, adjust eprom.
May 12, 2008 | Toshiba CF36H50 36" TV
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
Vertical hold
You dont have enough vertical sweep!! Best thing to check is the vert output device and I think its an IC . BUT before that check the b+ going to that device and see if its low. I will run through a silicon diode right next to the ic. Measure both sides of the diode and if theres a big voltage drop then the diodes bad. Now also these sets are common for the b+ filter cap off thge flyback transformer. Its the voltage line that feeds that diode and the vert output section. Now measure all caps out of cucuit as most will measure good if you dont. Also just for giggles right nrxt to the big IC that has the vert ,horizontal video and sound drive there is if im not mistaking the vert parts start with c4-- or the ic will be ic4-- Its a small cap that will sayc4-- attached to nothing but the ground and one pin of the ic. I've seen this cap cause all sorts of vert problems in the past as its the vert waveshaper capacitor for the vert osc/drive. Good Luck
Apr 17, 2006 | Sharp 25VT-J100 TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
