Question about Polaroid TTM-2003 Combo
Where to find a schematic
I have tried to contact Polaroid to get a schematic for this set, but just get the run around. No one seems to know wher to get one. The unit failed after 9 months of use. (3 month warranty). Problem may be in the low voltage power supply. One of my phone calls led to www.pettersservice.com where a free bunch of service manuals can be downloaded. The site is for LCD and Plasma TV. Not for the old CRT unit TTM 2003. Any ideas would be helpfull. Thanks
  • 934 Answers
That's because Polaroid is the ONLY place you'll be able to get one... Polaroid didn't build that unit, a company called Prima built that TV and put the Polaroid brand on it. They do that for several other mnaufacturers also like ADVENT and AUDIOVOX and technicians have been screaming their heads off for years. It goes something like this, "...if you're too *&^%&^&$ stupid to build and support the TV yourself why put the customer through hell when it breaks down - and it will eventually break down. The answer's simple, just quite farming your dirty work out of the country." Prima is located somewhere in Canada, good luck finding them.. And a better known PWW Services are here in the states. But like Prima, the lights are on and no one is home... On a bright note though, you can go to PWW Services web site and find an assortment of user manuals for the various brands free... So, about your problem - - this one is a definately take it to the shop. And don't be surprised if it takes forever for the tech to blindly trace test every component in the SMPS just to get the darn thing running again. It will be a bit like threading a needle with a sludge hammer / blind folded... Good Luck! Bill
Posted on Jun 07, 2007
SOURCE:
Schematic for power supply for 26'
That I do not have. However the basic principles of locating bad capaictors and bad solder joints is pretty much universal. The Polaroids seem plagued with bad solder joints the most.
Dec 29, 2011 | Polaroid Televison & Video
My 40 inch Polaroid LCD tv screen won't come on
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please revert back for more help.
Rylee
Dec 23, 2011 | Polaroid Televison & Video
Where can I find a (download)driver for the Polaroid t730 camera?
Polaroid does not supply drivers on their support pages...
Try this one. Version 1.0 from July 5, 2007. Nothing newer seems to be around.
http://www.downloadplex.com/Drivers/Digital-Camera/Polaroid/polaroid-digital-camera-t730-driver_176507.html
Dec 12, 2009 | Polaroid T730 Digital Camera
The flash on my polaroid t831 is too bright. it
set auto white balance, or use a small paper in front of camera, seems like your camera is defective.
Nov 08, 2009 | Polaroid T831 Digital Camera
No sound on my polaroid tv tlu-o1541 cu
Hi, Try to reset the tuner settings to cable or what ever your are using for a signal. and run the auto search again. Thanks.
Sep 22, 2009 | Polaroid TLA-01511C 15 in. LCD Television
POWER SUPPLY BAD, NEED SCHEMATIC DIAGRAM COMPONENT LEVEL
Polaroid will not release component schematics not even to service centers as they are designed to replace the entire modules while under warranty out of warranty there is very little Chance of obtaining new replacement parts. As i have a 2006 LCD and a 2007 Plasma Polaroids and polaroid told me they are considered a disposable TV replacement parts are not available and suggested that I try ebay
Apr 29, 2009 | Televison & Video
Will not turn on
It sounds like you have a power supply problem. I would suggest that if you are going to effect repairs on this unit yourself you get a schematic of the set and use a multimeter to test the power supply levels. This is good for a starting point, if you need any other assitance you can contact me or any of the FixYa experts to aid in additional troubleshooting.
Apr 30, 2007 | Polaroid FLM-3201 Television
FDX-0700T has no picture
Here is a website that offers a replacement inverter board that will fix the backlight issue on this monitor
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Jul 25, 2006 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid TTM-2003 Combo Logo
181 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
