Question about GE Washing Machines
I have a GE hydrosoft top loading washing machine and I think one of the suspension rods is broken, i can get everything taken apart on the top of the machine but can't get to the rods
  • 6 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
the dr
  • 447 Answers
SOURCE: ge harmony top load model wpgt9350copl washing machine
This is a very complicated machine utilizing no transmission, rotor/stator type drive motor, and a locking/unlocking clutch mechanism design to either engage or disengage the wash basket. These machines are tricky even for professionals to properly diagnose.
Posted on Jan 19, 2008
SOURCE: My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Posted on Nov 14, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
My ge washer shakes alot
The washer has 4 rods that support the tub for suspension and four rubber straps to keep lateral movement to a minimum. With time the straps which are called bungys get stretched and worn out. Some times water sloshes over the top of the tub . SERVICE MANUAL
Jun 12, 2012 | GE WJRR4170E Top Load Washer
Washer squeaks When washing and rinsing on the right side upper drum.
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
Dec 23, 2010 | GE WBSR3140DW Top Load Washer
How do I locate the water pump on a Roper top loading washing machine?
Check the four suspension rods suspending the outer tub to the top of the cabinet and the counterweight at the bottom front of the tub. Make sure the four suspension rod assemblies are intact and no sign of damage and the counterweight is in place.
Sep 26, 2010 | Roper RAX4233PQ Top Load Washer
My washing machine tub is like it is off track
One of your suspension rods is broken. Or one of your bungy straps(WH1X2727) is gone. This video shows how to get into the machine:
Training manual
Aug 27, 2010 | GE WBSR3140DW Top Load Washer
Tub is crooked
sounds like 1 suspension rod is broken . undo 2 screws at front under lid to lift top hob up. do not lift it too high.look at which side is lower to see if suspension rod is faulty. if suspension rod is faulty replace it. please reply if u need more help. turn power off b4 u work on it dont want any accidents. good luck
Mar 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Ge profile washing machine
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
In the wash mode, when agitator is going left and then right. There is a loud rubbing, deep pitched squealing moise. It appears to be coming from the four rods that support the tub. Please help
If you take the front panel off, then the washer's top, you can un-hook those support rods (do only one at a time) and put a dolop of lithium grease on the top ball and socket area of each of the four suspension rods.
Feb 17, 2010 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
283 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
