Question about Coby MPC-848 MP3 Player
Battery drains too quick for AAA
The battery dies too quick! and theres no option to turn the neon light off. it should only come on at the touch of the button, and it stays on the whole time. it drains the little AAA battery too quick..i love the design but u need to make changes.. or make a built in battery that we can recharge through wall outlet
It some times depend on the type of batteries u get.......
You should try to get three types of higher brands of batteries...
if that does not work get Litium rechargeables....with the chager..
Posted on Jan 11, 2009
2000 Dodge neon drain Bolt came out of the oil pan all the oil came out the car kind of cut out and died seems to be sees but wanted to see what other people think I should do or any suggestions
If it died, it either overheated or seized.
Replace the oil drain plug, refill the oil and try to start it. If it sounds labored, like it's having a tough time turning the engine when it's cranking, you've got some troubles. The Neons are notorious for having engine heads that distort after over heating and require replacing. This isn't a fun job or inexpensive to have done. When that temperature guage turns on, turn the car off immediately.
Apr 12, 2017 | Dodge Cars & Trucks
1996 NEON ... YESTERDAY ON THE WAY HOME IT DIED 6 TIMES ... RUNS OK ... GET BACK ON THE ROAD ... GO A MILE OR SO .. DIES AGAIN ANY THOUGHTS ?
There's multiple possibilities. Some of them are a partially clogged fuel filter, poor fuel pressure, a bad sensor or sensors, etc...
Have you checked/changed the filter? What's the fuel pressure?
You can access a simplified version of the trouble codes on this model - with the car off, turn the ignition switch on, off, on, off, and on again relatively quickly. The check engine light will blink out the codes. An example would be blink, pause, blink, blink. This would be code 12. Chilton's or Haynes books give you the code's meaning (that code means battery disconnect). These can at least give you a place to start.
Aug 04, 2010 | 1996 Dodge Neon
My Nikon N2000 works great but it has one problem , on one side of the battery compartment the two aaa dies very quickly but not the other two aaa batterys
You may have some corrosion under the battery compartment causing a short that drains the batteries. You can safely remove the battery compartment with a small cross point screwdriver. Remove the batteries, there should be 5 screws, The only concern is that some models had wires soldered at the contact end, but most had only spring contacts. Check the backside and end of the compartment for a white or green build up.
Jan 25, 2010 | Nikon N2000 35mm SLR Camera
I have no power to my ti-83 plus, I changed batteries and the backup battery is still good
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 22, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83 isnt turning on after i changer all the batterys
C. Third option
D. Last option
Hope it helps.
Nov 21, 2009 | Texas Instruments TI-83 Plus Calculator
Changed out both the back up battery and the 4 AAA's .calculator is still not coming on. what can i try next.
C. Third option
D. Last option
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
It is just not working. it is freezing on me?
C. Third option
D. Last option
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Nov 19, 2009 | Texas Instruments TI-84 Plus Calculator
When I turn on the Ti-83 the screen comes up in all grayed out and can't do anything except turnoff
C. Third option
D. Last option
Hope it helps.
Nov 16, 2009 | Texas Instruments TI-83 Plus Calculator
2005 dodge neon is having problems with jumping and dying and the engine light is on
The alternator is more than likely bad. If you jump start all the time and the car dies quickly it is the alternator, if you jump start all the time and it runs until shut off, but will not restart it is the battery.
Jun 24, 2009 | 2005 Dodge Neon
WONT STAY ON
check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Sep 26, 2007 | Vivitar ViviCam 3780 Digital Camera
Coby MPC-848 MP3 Player Logo
46 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
