Question about Comfort Zone CZ-530 Compact Heater
Cz- 530 broken element
Where do I get a replacement element? The fan runs fine but the element burnt out on the top line...
Main fan oven blows fuse when I turn heat on , does not blow when just fan is this the element ? Which is blown . Many thanks Barry
No manufacture or model hard to steer in the right direction there is definitely a short if the element is not broken or burnt thru where it is touching the cavity then look elsewhere for a burnt wire touching the body or the element terminal possibly touching the back panel all the Whirlpool Products I repair the element can be removed from the front inside the cabinet unless you have a wall oven and it's the bake element
Jan 23, 2015 | Ovens
Fan stopped working on Jennifer air downdraft electric cooktop. Elements still work fine. Circuit breaker did not trip. Took switch out of line by directly connecting fan leads. Still did not work when...
Generally there is a plug for the fan motor under the range, the panel where the drawer would be should lift off, you will then see the power to the fan motor. The fan motor is only 120Volts not 220V
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | Jenn-Air Cooktops
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Bosch fan oven element replaced because old one was burnt out. fan working fine light coming on but element wont heat up
It must be a faulty thermostat as well that sometimes happens when an element blows.
Dec 12, 2010 | Ovens
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Fan runs no heat from element
IT SOUNDS LIKE THE ELEMENT HAS BURNT OUT , REMOVE THE BACK PANEL FROM THE INSIDE OF THE OVEN BUT FIRST MAKE SURE THE POWER IS OFF WHEN THE PANEL IS REMOVED DISSCONECT THE TWO WIRES FROM THE HEATING ELEMENT TAK IT TO A PLUMMERS SUPLY STORE FOR REPLACEMENT , REPLACE NEW ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 16, 2009 | Ovens
Comfort Zone CZ-530 Compact Heater Logo
24 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
