Question about Vizio Televison & Video
32 INCH VIZIO FLATSCREEN MODEL E321VT HAS A UPSIDE DOWN PICTURE
SOURCE: Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Posted on Sep 01, 2008
budmrtn
  • 11361 Answers
SOURCE: No picture at all
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Posted on Oct 30, 2009
roety
  • 585 Answers
SOURCE: Videos upside down on my Vision Quest 32 inch
Hi my name is Roety,
I can help you with your issue ,
Using the TV remote enter the menu and look for invert setting or flip setting
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 29, 2009
SOURCE: sound but no picture
i have a 32 inch turns on but no picture could it be the fue?
Posted on Nov 24, 2010
  • 11800 Answers
SOURCE: Vizio 42" LCD Flatscreen TV lost picture It is a
Both: the one that never lights is totally dead, the one that lights has a short. But, if you can locate the short on that board and remove it (replace the failing part and clean the burned board) its salvageable.
Unfortunately the big problem is in the power source: the 24v that is used to power the inverters and the audio amplifier is working while the 12 and 5 v lines that are used to power everything else are dead - which is a very bad sign, it means that there's something very bad in the mainboard, you will have to verify it .
Posted on Jan 16, 2011
No picture on tv
I have vizio flat screen tv get sound on it but picture and the screen is blue and my email addersse is Vickie summers @ yahoo .com thank you Vickie .
Feb 19, 2014 | Vizio E321VL 32-inch 720p LCD TV...
Screen upside down
Make sure if there is any option under PICTURE Settings that changes picture view mode.
Jan 11, 2014 | Vizio Televison & Video
My dad's 6 yr. old Vizio 32 inch flatscreen said 'no signal,' then faded to black. Is this the end????! Surely not!
No signal indicates that the TV is not getting a signal from a source cable, so no, it's not the end! The first thing you can try is to verify that all the connections between the TV and the cable, satellite, DVD player, or whatever device you're trying to use have not come loose and that the device is powered on. If that doesn't fix the problem, your next step would be to check what input option the TV is on. For example, when using a cable source with an HD cable box, you'd want to use your remote that came with the TV to check the component or HDMI sources. To do this, look for a button on the remote marked "source" or "input." If the remote has neither of those, sometimes the Menu button can get you to input options. Once you've selected the right source, your TV should have a picture again, but as a last resort, you can contact either your TV manufacturer or cable/satellite provider.
Mar 15, 2011 | Vizio L32 32 in. LCD HDTV
Our vizio flatscreen tv just went off and won't come back on.
Look and see if the fan is working on the inside.
It may a built-up of dust.
Thanks,
Wbigtodd
Jan 01, 2010 | Vizio L32 32 in. LCD HDTV
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
Hello. I have a Vizio 32 inch LCD flatscreen TV. About 5-6 years old. Once on, it works fine for a minute or two but then the screen goes blank and the orange Vizio blinks on and off. Every time. Does...
this is a main board problem. Replacing this will resolve the problem for you. if you want a tech to come to your home and fix it for you, you can call ITI at 888-248-2708
Jun 18, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Jun 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
85 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
