I wish to request your kind help as I have unexpectedly lost access to Microsoft Word 2007. The program was in full use until today on my emachine e732, with Windows 7 Operating System. When I clicked to open a saved Word document, a Windows Installer box opened with the message " Preparing to install". This installation was unexpected as I had Word 2007 pre-installed and in full use. Then the fatal error appeared: Error 25004 ConfigXml not specified. A valid config.xml file must be authored when deploying'[null]'. This unusual failure is preventing the system from accessing any Word documents. Is there any help to get around this problem by uninstalling and then re-installing MS Office 2007 suite so that my Word documents can be accessed again, please. I would be most grateful for your kind help and advice, if possible. The mahine that I'm using is an emachine. All the system software and the MS Office suite were preloaded before I took delivery of the laptop. There are not any installation CDs for re-installation of applications in the event of the current type of problem. Kindly advise further if there are any procedures for the reinstallation remedies, please. I would be most grateful for your kind help. Kind regards Elvira
SOURCE: Problem installing office 2007.
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in
or Microsoft Save as PDF or XPS installed, this may be the culprit. In
both cases, by performing an uninstall on this add-in via the Control
Panel, and then installing Expression Web, everything works okay. You
can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
go to website www.martau.com download uninstaller and completely remove previous version office. Using this application every entry related to previous version will be removed
SOURCE: When I attempt to install
Try to run the Windows Update and install any necessary updates and then try to reinstall the Office 2007.
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
