SOURCE: solenoid will not shut off gas when switch is off.
Have your mower running in park
pull the wire off off the solenoid if it is working correctly your mower will shut down less than 10 sec.
if not then it will have to be removed and inspected
sometimes the plunger gets hung up with dirt and or rust and or moisture
remove it and free it up manually and retry when you see it is not stuck anymore and operates without sticking
SOURCE: Proper procedure to adjust valves on Briggs and
YOU HAVE TO REMOVE THE PLUG AND ROTATE THE MOTER TO T D C THEN TUR IT HALF PAST THEN CK THE VAVEL CLARENC ARE YOU SURE THIS IS THE PROBLEM TELL ME WHAT ITS DO ING SO I CAN MAKE SURE THATS THE PROBLEM LET ME KNOW
SOURCE: I just want an owner's
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=42A707-2238-E1
Should fix you right up.
Testimonial: "I am sorry if I sounded rude about the manual. I just could not find the right link. Thank you for your timely answer. I 'm sure this will work."
SOURCE: briggs and stratton engine model
there are the basic things for an engine to start. air, fuel, and spark. if you are getting spark at the plug one down. try taking your air cleaner off and spray starting fluid into carb with choke open then close. if it starts and runs a litlle then dies then you have a fuel problem. take carb off and clean real good take bowl off and clean with carb cleaner. that should solve you problem if not let me know
