My acson R410A air conditioner yellow light blinking and stops cooling
Yellow light blinging and stops cooling
SOURCE: Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Posted on Aug 05, 2007
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
The light keeps blinking from green to yellow but the unit will not come on to either heat or cool
This is a sensor problum change sensor . And may be memori ic problum
Nov 30, 2016 | Heating & Cooling
My thermostat stopped working,i need to no what wires go where,i have a red,blue,yellow wiring
Red-R 24volts, Yellow-Y (Y1)cooling, blue-?
Not enough information provided. What system involved, heat, cool, heat&cool, gas heat, heat pump .
Apr 27, 2016 | Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Fujitsu AOU24CL - blinks twice - not cooling what does this mean? I can't find codes for this machine anywhere.
There are red green and yellow lights what is flashing, how many times is it on the controller ??
Sep 01, 2011 | Fujitsu 24C1 Air Conditioner
NO cold air
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Therefore I would request to add r410a refrigerant for better cooling. Thanks for contacting Fixya.
Jul 05, 2009 | Cfm Daikin R410a Split System Air...
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
