Question about Microsoft LifeCam VX-1000 Webcam
Display how can you adjust the settings on the camera.. it is displaying four pictures?
    Genius:
  • Microsoft Master
  • 1,102 Answers
You should be able to go into your camera program and change the settings
you'll find it in c/ program files
or control panel
Posted on Jan 17, 2009
Picture does not display
There could be something wrong with your display button, it's the one that has a triangular type arrow sign on it. If you mean it doesn't display as soon as you take the picture then you have to go into the camera settings. It may be set to not display or just display for two seconds. You can change that setting to longer on most decent cameras.
Dec 28, 2013 | Cameras
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Will not show picture and camera is working. Is
Not too much info here. Based on your statement, I'm guessing you are trying to connect a digital camera to your monitor to display pictures on it.
1) Does the monitor work fine as a monitor on its own?
2) Make sure you're on the right display/input setting on your monitor.
3) How do you know the camera's TV-out function is working? Have you tried it on other TVs?
Its possible that the camera is not in display mode. Its also possible that the camera's TV-out is not working. Its also possible that something about the output from the camera is not compatible with your monitor. I would try the following:
1) Test the camera on another TV to make sure the TV-out is working.
2) If its working, go to the appropriate input/source setting on your monitor, before connecting the camera. Then connect the camera, when the camera is off. If nothing displays then turn the camera on, and see what happens.
If that doesn't work, it may be possible that your camera displays in a different set of settings (resolution, etc) than your monitor is able to display. Also I would check the manual for your camera to make sure there isn't some way to adjust the settings.
Feb 16, 2010 | ViewSonic NX1932W LCD Monitor
When looking through the display screen the picture has a pink tinge. When reviewing the pictures they're definately pink in colour, especially the blues.
Try taking pictures and download them to a computer. Check the colors and evaluate the quality compared to what you have seen in the LCD display.
If the pictures are good and the colors seem to appear good on the computer, then some thing is either not adjusted correctly for the LCD or you may have a menu setting which is incorrect. Check all setting in the menus.
Test the camera again, and see what the colors look like in the LCD display.
If both the LCD display and the pictures on the computer are the same, then some problem exists in the camera, and may need fixing, or sell on a site such as Ebay for parts or repair as is.
Oct 25, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Displayed image is dark.
There should be a setting under the setup screen that should adjust conrtast and brightness.
If that doesn't help than that means that the light behind the lcd display of the unit has burnt out.
If you can't deal with it then it will be cheaper to just purchase a new unit than attempting to get in there to fix it. Also try to get it covered under warrenty if it is that problem
Aug 07, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Purplish hue to display image and picture on Powershot A75
Send to Canon, Theirs a recall on this model, Go to there web site look up service advisory, CCD malfunction. N/C
Feb 24, 2009 | Canon PowerShot A75 Digital Camera
Canon Powershot SD 1100ES - display problems
My mother has this model camera. I believe there is a setting in the main menu that will allow an energy saving mode that sets the display time or no display. If not it's under warranty and your retailer should replace it if it is within 30 days of purcase date.
I hope this helps, goood luck!
Nov 20, 2008 | Canon PowerShot SD1100 IS Digital Camera
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Microsoft LifeCam VX-1000 Webcam Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
