Question about Dell U2410 24 inch Monitor
Dell u2410 disassemble
My dell U2410f seems to have blown a fuse. I would like to open it up and see if it is something simple before I spend money on it. Typically Dell monitors are opened by gentle lifting the bezel away from the screen from the top left corner but I have applied a fair bit of gentle with no result. So - how do I disassemble a U2410? Thanks for your help.
5 Suggested Answers
SOURCE: dell monitor wh 320
Just done mine and the plastic case/frame is secured with clips all the way around.
Remove the stand/bracket screws
Place the panel on its top edge and look down on the underside join.
You will see two small notches where you can get a pen knife/lever in. Dont poke in too far especially where the buttons are.
Now lever the back off the front by leaning your knife/lever in the same direction as the screen front. Once you have the first clips free you can work all the way around in the same way taking care not to damage the plastic much.
I hope that helps someone else who is stuck like me at first and found this Q unanswered and eventually I decided I had nothing to loose lol.
Regards
Posted on Jan 30, 2008
  • 46 Answers
SOURCE: how to open dell wh 320 monitor for repairs
check out this link for videos on how to open dell LCD monitors.
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
skotkolr
  • 558 Answers
SOURCE: dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Posted on Feb 17, 2009
SOURCE: to dismantle the dell e153 15 inch monitor
The front and rear of the case is held together with latch and hook type fasteners, this is how I cracked mine apart.Remove the 4 screws holding the stand on the back of monitor, start with either bottom corners and insert a flat head screwdriver or similar soft object such as a wooden popcicle stick into the crack and work your way up the side to the top, then across the bottom, and up other side to top, I then ease the case apart at the top with no effort.
Posted on Feb 21, 2009
How to replace a wireless card in Dell Latitude E5430.
Dell manuals tell you how to disassemble and replace parts. So do the research, locate and remove part, and replace with same. Simple, mais oui?
Dec 28, 2016 | Dell Computers & Internet
Dell wont turn on
i have a Dell ultrasharp u2410. I turn the screen on and you can see the blue light ascending, but hen it stops and only orange light comes on and nothing, I think it says in power save mode.
Jan 10, 2014 | Computers & Internet
Dell computer wont start up
Tough one, but inspect the motherboard for a blown capacitor. You could test the power supply with a simple voltmeter. Not to mention simply seeing anything lit with the case open while powered one. gl
Dec 12, 2012 | Dell OptiPlex GX280 PC Desktop
Dell Desktop monitor has flashing dots, black and white, all over the screen.
Check have you installed graphics driver properly in order to as per your monitor and as per your system or not.
Jun 20, 2012 | Dell U2410 24 inch Monitor
Same problem here with my Dell lcd monitor. monitor seems to be receiving the data from computer i play with the button in front but i can only receive data for no more than a couple of second,and then...
More likely to have cold solder joints, shorted out transistors in the inverter circuits, fuse.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Replacement board: http://www.lcdrepair.us
Sep 05, 2010 | Dell E173FP 17" LCD Monitor
How do i replace the bulb in my dell e153fp monitor?
Are you sure it is CCFL problem not the shorted out transistors or blown fuse in the inverter circuits?
LCD will have to be disassembled to get the lamp assemblies out and you need to get the raw lamps from www.lcdparts.com
, remove the old wires an resolder the wires back on to the new lamps.
Sep 01, 2010 | Dell E153FP 15" LCD Monitor
I need to disassemble my Dell Inspiron Laptop to
Manual is here:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
#1 Phillips Screwdriver is about all you need as far as tools
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Dont what to spend extra money if its something simple?
call the factory cause nobody gave me any solutions!!!!
Sep 22, 2009 | Passport 8500 Radar Detector
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell U2410 24 inch Monitor Logo
1,900 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
