My acson air conditioner yellow light blinking and stops cooling
2 Suggested Answers
dhj144
  • 80 Answers
SOURCE: My Air conditioner stopped putting out cool air.
The unit is overheating and tripping the internal overload of the compressor. Clean outdoor coils.....check outdoor fan to see if it turns or is siezed......possible bad Start/Run Capacitor which is a very common failure on condensing units......possible bad fan motor need replaced! Unit compressor can be cooled with a water hose to get it to reset the internal biometalic high limit switch that is located in the hermetically sealed compressor!
Posted on Aug 22, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Mini Split GE model AE1CD20DM. Not cooling. Why is the power light blinking green 6 times and stopping, repeating over and over?
This should be a "trouble code". In the owners manual or installation manual you should find a list of trouble codes that help us determine what may be the lead malfunction.
May 20, 2015 | GE Quiet-Aire Ductless Mini Split System...
Fujitsu AOU24CL - blinks twice - not cooling what does this mean? I can't find codes for this machine anywhere.
There are red green and yellow lights what is flashing, how many times is it on the controller ??
Sep 01, 2011 | Fujitsu 24C1 Air Conditioner
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Jun 03, 2008 | GE Deluxe AGM12AB Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
