Washer will not fill with water
Everything worked fine but today the washer will not fill with water. all connections are good and water supply is fine.
  • 1 more comment
  • billyluuuvvv Nov 30, 2012
    The pump works fine and the spin cycle is fine too. Just the filling of the water at the start does not happen anymore. The hose connections are good and and the mesh screen in the hose connections are clean.
    Whirlpool Washer Model is WWF 665
  • Richard Roth
    Richard Roth Nov 30, 2012
    You will need to replace the water inlet valve.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 54 Answers
SOURCE: zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Posted on Feb 14, 2008
  • 1028 Answers
SOURCE: Kenmore Washer Model #110.25862400
ck lid switch
Posted on Aug 29, 2008
SOURCE: LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Posted on Mar 18, 2009
localwonder
  • 6784 Answers
SOURCE: Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
Posted on May 20, 2009
  • 219 Answers
SOURCE: washer won"t fill with water
check your lid switch if its a top load
Posted on May 22, 2009
The washing machine will ot fill with water
Good Afternoon Friend,
I understand your Frigidaire Gallery washer, model# GLWS1339EC, will not fill with water. First, make sure that the water supply is adequate in area where your washer is located. Secondly, make sure the water supply faucets are completely open. Thirdly, make sure water is not being used elsewhere in the house. The water pressure must be at least 30PSI. Try to avoid running water elsewhere, while the washer is filling. Lastly, make sure the water inlet hoses are not kinked. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Gallery GLWS1339EC Top Load...
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
May 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Hot water doesn't work
Disconnect the hot water hose from the washer, put the hose over in the washer and run some water to make sure you don't have a plumbing problem. Look inside the valve where the water connects to the washer, there should be a screen that may need cleaning.
If everything looks and works good to this point then you will need a meter to see if power is getting to the water valve and to check the hot water solenoid on the water valve. No power to the water valve, then replace the water select switch. Bad solenoid, then replace the water valve.
Jan 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Zanussi aquacycle 1000 xc washer
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
WIL103 stopped taking conditioner
bit of a common problem, this sounds like the cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if i have helped rate me please
Sep 18, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
