Question about Kenmore Elite 45986 Front Load Washer
Wahser has quiet working and door is lick need to get close out?
I need to know if I can over ride the door lock
  • 640 Answers
You cant override it but you seem knowledgable..so take bottom panel of and reach up ,,theres a tab at bottom of lock pull it,,,onthejob
Posted on Jan 10, 2009
Why don't buttons on top panel work?
Do you mean that you have no response when the door is closed and you're trying to start the machine? My control panel becomes unresponsive when counter crumbs or dust gets into the tiny hole where the top of the door locks into the top of the dishwasher. Sometimes, it's as simple as just blowing into the opening, other times I need to use a tiny brush or q-tip to clean the contact in the top of the door where it locks into the control panel.
Nov 17, 2015 | Kenmore Dishwasher With Ultra Wash And...
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
I own a '99 Range Rover 4.6 hse. I recently reinstalled a battery that had gone dead. I cranked the engine but the alarm went off and the vehicle did not start. I am getting this message: gearbox fault. I...
Unfortunately, there is a trick to replacing the battery.
1) Open the Driver side door.
2) Open the Bonnet and take the battery cover off.
3) Use your remote to lock and unlock the car (keeping the driver side door open)
4) Pull the Negative Lead from the battery first, followed by the Positive Lead.
5) Change or replace with charged battery.
6) Closed down Bonnet.
7) Your windows, sunroof, and key FOB will not work... so follow the next steps.
7a) Insert your key, with door closed into the exterior lock on driver's side.
7b) While turning the key to lock the door, hold down the "lock" button on your remote for 5 seconds while in "lick" position
7c) Your remote will reset, and you should be able to use your remote now
7d) While driving, roll each window down twice. On your third attempt, you should only have to touch the window button, and the window will have reset
Enjoy your Rover!
MIke
May 21, 2010 | 1999 Land Rover Range Rover
1999 Honda CRV automatic door lock only works for three doors
the little motor that operates it inside the door is probably frozen, so it will need to be replaced!!
Jun 19, 2009 | 1999 Honda CR-V
Sliding door won't close/latch
First you need to determine if the issue is a door sliding issue or a door latching issue. These are 2 separate problems.
If the car/van was in an accident-take it to the bodyman.
If the railing is dirty or has a nail, penny, etc in the way this would also cause problems.
If the latch is already closed on the door lick it can't engage since it is already 'latched'.
Isolate the problem - try again! TJ
May 29, 2009 | 1994 Dodge Caravan
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
