Question about Sanyo MM-8300
HOW TO ERASE EVRYTHING ON MY MM 8300 - Sanyo MM-8300
2 Suggested Answers
SOURCE: to unlock code no. of sanyo mm-8300
use cdma workshop
Posted on May 26, 2008
HI dude! got a problem trying to find out where this bike is made
I do not recommend this bike. Honda, Yamaha, Suzuki are good choices. You can find a dealer all over the world. The bike is junk the first time a part fails if you can't get parts and service. Seen any dealers in your city? The bike is made in Taiwan. Here's the info you asked for, even though I advise against it. Top speed 65 to 70 mph Overall Height1170 mm (46.1 inches) Overall Width880 mm (34.6 inches) Overall length2110 mm (83.1 inches) Seat height810 mm (31.9 inches) Wheelbase1375 mm (54.1 inches) Fuel capacity - reserve12 l (3.2 gallon US) Dry weight126 kg (277.8 pounds) Enduro-Offroad ModelVR 150X ENGINE Type149 cc, air cooled, single cylinder, 4-stroke Standard compression 145 lbs Power13.5 hp (10.1 kW) @ 8300 rpm Bore x stroke (mm)62 mm x 49.5 mm Compression ratio9.6:1 Valves2 valves per cylinder IgnitionCDI Torque12.4 Nm (9.1 ft. lbs) @ 8300 rpm How about a top rating on this answer. Thanks!
May 28, 2009 | 2003 Hartford VR 150X
I Cant send MMs on my Blackberry curve 8300, please Help!
reset the settings.
rom the general menu under security, you can select wipe handheld, and then there should be a checkbox allowing you to wipe all 3rd party applications. This will remove all data and applications.
If you would like to erase the OS, use jl_cmdr (search either here or at blackberryforums.com, i dont have the direct link) and that will erase the OS. Then you can install the new OS to the computer, launch desktop manager, and you'll be all set. Doing that can take a while, so be patient.
rate this post plz
Feb 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
To unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Mar 14, 2008 | Sanyo MM-8300
Changing language on sanyo MM 8300
hi there
you can change back to default english by pressing shortcut keys.
press menu/ok
select settings
press options(right softkey)
then select language
now slect english.
hope this helps.
Feb 07, 2008 | Sanyo MM-8300
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Sanyo SCP-8300
I'd suggest a new battery, if money is no problem but otherwise, if you have a volt-meter of some kind, you could read the voltage output of the charger and compare that to what it says it should be in the input-output list usually printed on the underside. If it's fine, I'd try carefully cleaning the phone's battery and charger contacts with a small amount of rubbing alchohol and some cotton swabs or tooth-picks lightly wrapped in toilet or tissue paper. If it still refuses to work, you could see if a sales-clerk at your local phone store would let you try a new battery to see if it would work. Otherwise, you could attempt internal repair/cleaning like I outlined here- keys won't work on sanyo mm 8300 phone.
Oct 09, 2007 | Sanyo MM-8300
Cell Phones Logo
19 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
